Waste Overflow options & installation
Discussion in 'Shower & Bathtub Forum & Blog' started by DavidTu, Jun 16, 2011.
  1. DavidTu
    DavidTu Member
    Dec 3, 2009
    Seattle, WA
    Have cast iron 2" tub drain & p-trap in place. Now need to connect the W&O to that. As there will not be any access panels am I correct that I cannot use a slip-joint type W&O kit and/or connection to the CI drain? (I've seen HJ claim in a thread he hasn't installed an access panel in 50 years... so who is using all these tubular W&O kits?! They all use slip joints, right?)
    Assuming no access panel, then, am I correct in thinking my only option is a ABS or PVC sch 40 kit that is glued up? If not, what other options are there? (I would make the connection to the drain, then, with a Mission Coupling 2" CI to 1.5" plastic, right?)
    The only "remote operated" drain I see for Sch40 W&O is the cable-driven ones. Any recommendations (i.e. brands) or cautions?
  2. hj
    quote; so who is using all these tubular W&O kits?! They all use slip joints, right?)
    The plumbers using tubular W&O kits without an access door are the ones who install them correctly the FIRST time, so they do NOT have to get to them until the tub is removed for remodeling.
  4. DavidTu
    DavidTu Member
    Dec 3, 2009
    Seattle, WA
    Whoa... thought code required an access panel... does it not? I'm in Seattle, if it matters, but I am/was under impression that the panel was not optional. Please 'splain.
Similar Threads: Waste Overflow
Shower & Bathtub Forum & Blog Need help picking a bathtub waste overflow (BWO)/drain Jun 17, 2016
Shower & Bathtub Forum & Blog Help me identify a tub drain/waste/overflow handle Apr 12, 2016
Shower & Bathtub Forum & Blog Question on plunger/stopper inside a tub waste overflow drain Dec 19, 2015
Shower & Bathtub Forum & Blog How to replace a clawfoot tub faucet and waste and overflow Oct 18, 2013
Shower & Bathtub Forum & Blog Stumped - How to Replace Tub Waste/Overflow w/ Very Tight Clearance to I-Joist Jul 5, 2012
