Washing machine venting
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Rich B, Apr 25, 2009.
  1. Rich B
    Rich B DIY Senior Member
    Sep 13, 2008
    New Jersey
    I have two washing machine drains to plumb and vent. I am upgrading them to the proper size 2" using wyes into a short 4" horizontal C.I. section. I can go straight up with a vent. The two washer drains are seperated by a block wall in the basement, as this is a 2 family house. Can I use 1-1/2 for the vents, go straight up and join the two together in the common wall above? From there it would join with a common vent for one of the bathrooms upstairs. A tub and a sink....then up thru the roof and increased to 2"....The existing washer drains had no vents and are 1-1/2" and are poorly done in galvanized pipe.
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    I believe what you have planned will work fine, but a real plumber will have more insight as to codes.
  4. hj
    vents
    One thing about the common wall between units, is that it may be considered a fire wall and, if so, any penetrations should be made and sealed with fire resistant materials.
  5. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Under my codes, once you connect the two vents together you'll need to be at 2" for the vents.
    What is your location or what codes are you under?
    A sketch or picture would likely help further.
  6. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Which code is that?
  7. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Florida Plumbing Code 2007, based on IPC.
    Common, wet and/or waste stack 1-1/2" Vent is only good for 1 dfu.
    Also under FPC the min vent for 1 clothes washer is 2".
  8. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Me thinks you have mis-interpreted the IPC. You can wet vent an entire bath group off an 1 1/2 pipe.
  9. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    I may have. I only have the FPC, the foreward in the FPC indicates its basis on IPC.
    FPC2007 Table 909.3
    Wet Vent/DFU=
    1-1/2"/1 dfu
    2"/4 dfu
    2-1/2"/6 dfu
    3"/12 dfu
  10. techinstructor
    techinstructor New Member
    Apr 24, 2009
    North Carolina
    North Carolina code is similar to FL.
    Table: 908.3
    1/1/2"/1 dfu
    2"/4 dfu
    2 1/2" to 3"/6 dfu
Similar Threads: Washing machine
Plumbing Forum, Professional & DIY Advice How To Drain Utility Sink To Washing Machine Drain? Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Help - washing machine hose and standpipe issue Jan 20, 2017
Plumbing Forum, Professional & DIY Advice Washing machine wall box suds backing up. Jan 5, 2017
Plumbing Forum, Professional & DIY Advice Washing machine inlet hose lifespan Dec 31, 2016
Plumbing Forum, Professional & DIY Advice Washing machine water feed shaking around Dec 31, 2016
