Washing machine/sink drain and vent
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by garrettgjp, Jan 21, 2013.
  1. garrettgjp
    garrettgjp New Member
    Jan 21, 2013
    Grand Forks ND
    I am a new home owner and this will be my first ever DIY plumbing project.
    My washing machine drains into the laundry sink and I am wanting to have it drain into a seperate pipe and figure out how to vent it properly as well. I have included pictures of the current setup, any suggestions or advice would be greatly appreciated since I am not sure how to go about this correctly.
    Winter 2012 018.jpg Winter 2012 019.jpg Winter 2012 020.jpg Winter 2012 021.jpg Winter 2012 022.jpg
  2. jimbo
    jimbo Plumber
    San Diego, CA
    The photo shows an S-trap which is illegal, because it self-siphons. Also, it appears to drain into a drain stack, and therefor there is no vent.
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    First you will have to cut out a section of the cast iron and install wyes for the new drains. Then you will have to run a new vent from the basement up through the roof. Unless you are well equipped and quite skilled, this will not be a very good project for you to learn about plumbing.
  5. Hammerlane
    Hammerlane Member
    Oct 22, 2011
    Above fitting #5, there can be no other fixtures draining into that stack to have that vent setup be proper?
  6. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    That is Correct!!
  7. garrettgjp
    Jan 21, 2013
    Grand Forks ND
    Thanks, this is clearly over my head. I'll hire someone to take this on and watch and learn. Thank you again to everyone who responded!
Similar Threads: Washing machine/sink
Plumbing Forum, Professional & DIY Advice My choices for washing machine drain... Saturday at 5:18 PM
Plumbing Forum, Professional & DIY Advice Washing Machine Standpipe and Sink Drain tied to one drain? Mar 20, 2017
Plumbing Forum, Professional & DIY Advice Proper venting of washing machine and sink drain in basement Mar 13, 2017
Plumbing Forum, Professional & DIY Advice Moving washing maching 90 degrees to new wall Mar 13, 2017
Plumbing Forum, Professional & DIY Advice How To Drain Utility Sink To Washing Machine Drain? Feb 9, 2017
