Washing machine makes toilet overflow with suds - ?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by pogo, Jan 1, 2009.
  1. pogo
    pogo New Member
    Dec 30, 2008
    Hi:
    My laundry room is upstairs and sometimes when I run a load of clothes the toilet in the bathroom downstairs as well as the sink drain start sudsing up - It looks like a bubble bath coming out of the toilet and sink. What is going on with my plumbing? Should I be worried? I just moved into this house and have never seen anything like this. The previous owners mentioned nothing of it (of course!!)
    thanks
  2. Cass
    Cass Plumber
    Nov 12, 2005
    If your washing machine is dumping and making profuse suds pop up in a toilet then you are using to much soap...when a washing machine dumps its water there should be barely any suds...excess suds is to much soap...beyond that you may have a problem with a partialy clogged drain or vent or both causing it to back up but until you reduce the suds it is only a guess...how old is your home?
  4. theplumber
    theplumber Member
    Dec 20, 2008
    CA
    2 possibilities. 1 - your sewer is mildly restricted somewhere due to roots or use. 2 - it was plumbed poorly and you can't fix it w/out redoing the drainlines affecting you.
  5. Probedude
    Probedude New Member
    Nov 25, 2008
    CA
    Or you're blessed with soft water. Out where I live the water is very hard so I put in a softener about 6 years ago. Even with minimal soap there was a good quantity of suds.
  6. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    Yes, and regardless of water quality or soap quantity.
    I once had a similar problem at a place I was renting, and I soon discovered the septic tank was dumping into a "drain field" no larger than a five-gallon pail. My wife and I discovered the resulting drainage problem when two or three loads of wash came up through a toilet and all over the floor on a lower level.
    Either by checking for yourself or by calling in a pro, you need to find out what is wrong before your toilets begin to overflow because their discharge has no place to go.
  7. pogo
    pogo New Member
    Dec 30, 2008
    The house is about 20 years old - if I poured drano down the pipe where the washer discharges would that be ok? Or is drano really a band aid ?
    thanks
  8. leejosepho
    Nov 23, 2006
    Probably more like a waste of time and money, then a potential danger to the pro who will be clearing the line.
  9. Cass
    Cass Plumber
    Nov 12, 2005
    You can try if you like and if you do, do it at night before bed and leave it till the AM....I doubt it will work but if you have it and want to use it...have at it...99 times out of a 100 it won't work...
Similar Threads: Washing machine
Plumbing Forum, Professional & DIY Advice How To Drain Utility Sink To Washing Machine Drain? Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Help - washing machine hose and standpipe issue Jan 20, 2017
Plumbing Forum, Professional & DIY Advice Washing machine wall box suds backing up. Jan 5, 2017
Plumbing Forum, Professional & DIY Advice Washing machine inlet hose lifespan Dec 31, 2016
Plumbing Forum, Professional & DIY Advice Washing machine water feed shaking around Dec 31, 2016
