Washing machine drainage
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Bundy, Dec 16, 2007.
  1. Bundy
    Bundy New Member
    Dec 16, 2007
    Howdie all,
    I've recently moved my furnace from one side the house to the other. By doing so I needed to remove the double laundry tub in the basement.
    But as you can see from the image 3" copper stack with a 1" vent and I beleive the drain starts as 1 1/2" with a reducer to a 2" drain.
    Problem is... I can't move the wash machine cause the new furnace is just to the right of the drain and I require at least 24" from the front of the furnace door.
    What would be the best way to drain the washer? I know I'd need at least 2" drain for a standpipe.
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    It looks to me like that taped 45 ought to be fixed first, and that you have enough room between the stack and the wall to install a new trap right after that tee -- get rid of the slip-joint connection and have someone solder a female adapter -- and then run over a bit and up for the washer drain pipe. Or, maybe you could even get the trap in behind everything else. That would be my own DIYer approach.
  4. Bundy
    Bundy New Member
    Dec 16, 2007
    If I replace that wye with a wye facing in the opposite direction then a p-trap and stand pipe for the washer? Vent between trap and stack to the existing vent using some 90s?
    There is a possibility of replacing that entire stack, it drains a toilet and a tub. Nothing else fed into into that stack.
  5. leejosepho
    Nov 23, 2006
    I cannot see any problem there, but I am not a professional plumber.
Similar Threads: Washing machine
Plumbing Forum, Professional & DIY Advice How To Drain Utility Sink To Washing Machine Drain? Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Help - washing machine hose and standpipe issue Jan 20, 2017
Plumbing Forum, Professional & DIY Advice Washing machine wall box suds backing up. Jan 5, 2017
Plumbing Forum, Professional & DIY Advice Washing machine inlet hose lifespan Dec 31, 2016
Plumbing Forum, Professional & DIY Advice Washing machine water feed shaking around Dec 31, 2016
