Washing Machine Drain
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by seeker, Jun 14, 2006.
  1. seeker
    seeker New Member
    Jan 22, 2005
    I have a home in upstate NY. The washing machine is in the basement. The drain pipe is about 5' off the floor connected to the main drain(3' off floor) in the basement going to a septic tank. The drain line has a trap but the vent is open to the basement and not vented outside. Is this ok? Do I need to have it vented through the roof (is that even possible now) or is there another solution.
  2. Cass
    Cass Plumber
    Nov 12, 2005
    Go to L***S or a plumbing supply house and buy an air admitance valve.
    Install the valve on the vent.
    What kind of pipe is it? Copper, plastic, galvanized?
  4. seeker
    seeker New Member
    Jan 22, 2005
    The pipe is plastic
  5. Cass
    Cass Plumber
    Nov 12, 2005
    Depending on the size of the vent pipe you will need a 1.5" female adaptor to glue on the vent pipe the put some teflon tape on the threads of the AAV and thread it on.
    The AAV comes with a 2" X 1.5" female adaptor in case the vent pipe is 2".
    The AAV will let air into the plumbing system when needed but won't let sewer gas into the house.
    Is the pipe white or black?
  6. seeker
    seeker New Member
    Jan 22, 2005
    The pipe is white
  7. Cass
    Cass Plumber
    Nov 12, 2005
    You need to get PVC as opposed to ABS and glue to make it work.
Similar Threads: Washing Machine
Plumbing Forum, Professional & DIY Advice My choices for washing machine drain... Yesterday at 5:18 PM
Plumbing Forum, Professional & DIY Advice Washing Machine Standpipe and Sink Drain tied to one drain? Monday at 5:06 PM
Plumbing Forum, Professional & DIY Advice Proper venting of washing machine and sink drain in basement Mar 13, 2017
Plumbing Forum, Professional & DIY Advice How To Drain Utility Sink To Washing Machine Drain? Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Help - washing machine hose and standpipe issue Jan 20, 2017
