Washing machine drain layout
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by 1832 farmhouse, Jul 7, 2013.
  1. 1832 farmhouse
    1832 farmhouse New Member
    Jul 7, 2013
    Horsham , PA
    Hello,
    This is my first post and I hope the pictures come through ok. I am DIYer with a wide knowledge of construction.
    I am moving laundry to 2nd floor while remodeling and want a extra eyes on my layout.
    I current setup is dryfitted together.
    thanks
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I can't see for sure, but does the vent go to the outside or is than an AAV? AAV venting may not be OK where you are.
  4. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    Even if the AAV is permitted it must be in a location where it can be serviced.
    John
  5. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    AAV's don't work on washing machine drains. Washer drains are a pressure assisted drain. AAV's only let air in, not out.
  6. 1832 farmhouse
    Jul 7, 2013
    Horsham , PA
    It is a AAV. I will have a access panel in front of it. I have never heard that AAV's could not be used on washing machines.
    I thought a AAV open and closes?
    would it not work with the pressure that washer machine discharges?
    Thanks
    I have had AAVs installed on previous piping in another home area in my on a drain line.
  7. 1832 farmhouse
    Jul 7, 2013
    Horsham , PA
    would anyone install a cleanout somewhere in my layout?
  8. johnjh2o1
    Aug 9, 2009
    Retired
    Florida
    AAV's only open with a negative pressure.
    John
  9. 1832 farmhouse
    Jul 7, 2013
    Horsham , PA
    wouldn't there be negative pressure behind the water as it passes down the tee?
  10. johnjh2o1
    Aug 9, 2009
    Retired
    Florida
    On a pumped drain such as a clothes there can be a positive pressure caused by the water displacing he air in the line. That will not allow the AAV open.
    John
  11. 1832 farmhouse
    Jul 7, 2013
    Horsham , PA
    I see. very bummed out right now. Things now means another roof penetration? do they make a vent for my situation that would exit through the wall ?
  12. johnjh2o1
    Aug 9, 2009
    Retired
    Florida
    You could connect it to another vent in the attic.
    John
  13. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
  14. Gary Swart
    Sep 1, 2004
    Yakima WA
    Nothing says you can't go through the wall and then up with a vent.
Similar Threads: Washing machine
Plumbing Forum, Professional & DIY Advice How To Drain Utility Sink To Washing Machine Drain? Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Help - washing machine hose and standpipe issue Jan 20, 2017
Plumbing Forum, Professional & DIY Advice Washing machine wall box suds backing up. Jan 5, 2017
Plumbing Forum, Professional & DIY Advice Washing machine inlet hose lifespan Dec 31, 2016
Plumbing Forum, Professional & DIY Advice Washing machine water feed shaking around Dec 31, 2016
