Washing Machine Drain in Basement w/ CAD Drawing
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ForkWheelDrive, Mar 28, 2013.
  1. ForkWheelDrive
    ForkWheelDrive DIYer / Mech Engineer
    Feb 3, 2012
    Fork, MD
    I am in the process of installing a washer and dryer in the basement of my 1950's house. There were no dedicated laundry utilities before so they are all being added. I am trying to figure out how the washing machine drain could work. The attached drawing shows the existing piping to the septic system and the proposed routing of the washing machine drain line.
    I know that I could drain into the laundry sink and pump it out with the Zoeller laundry pump, but I am trying to avoid that. I'd like to keep it simple and not rely on another piece of equipment. The pump is also a significant electrical draw at 10 amps.
    [​IMG]
    Would this proposed design work? Here is my thinking:
    -The washing machine specs indicate no more than a 8' rise.
    -The horizontal run along the bottom would act like a trap.
    -The 3" vent above and the close proximity to the 6" drain directly into the septic act like the standpipe.
    Any suggestions are appreciated. Please let me know if there is any additional information I can supply. Thanks!
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    That would not work, nor would it meet any code requirements. You will need a basin and pump system to pump the waste from the sink and laundry into the main line.
    A washer must be drained to a laundry tray or a standpipe with an air gap. The fixtures must have proper P-traps.
  4. sethamin
    sethamin New Member
    Feb 21, 2013
    Brooklyn, NY, United States
    I am by no means an expert, but I see many things wrong here.
    -Your standpipe (if you can call it that) has no trap.
    -It also has no vent, or rather, you're trying to use the section of pipe running to the above bathroom as a wet vent, which is definitely not allowed.
    -And you're only using a 1" drain for a washing machine? I'm pretty sure the minimum is 2", and I've heard (ancedotally) that newer washer machines really need 3" (even though code does not dictate this).
  5. Terry
    Aug 17, 2004
    The Zoeller pump is your best option there.
    Do you really want waste backing up into your washer?
  6. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    You could get by with a small system like the Liberty 405. It will still require proper DWV.
  7. ForkWheelDrive
    Feb 3, 2012
    Fork, MD
    Thanks for the suggestions! Like I said I was trying to keep it simple so that's why I sketched the most direct option but I was definitely unsure about it. Looks like I will use the laundry pump.
Similar Threads: Washing Machine
Plumbing Forum, Professional & DIY Advice Plumbing washing machine with existing dishwasher Today at 7:12 AM
Plumbing Forum, Professional & DIY Advice My choices for washing machine drain... Saturday at 5:18 PM
Plumbing Forum, Professional & DIY Advice Washing Machine Standpipe and Sink Drain tied to one drain? Mar 20, 2017
Plumbing Forum, Professional & DIY Advice Proper venting of washing machine and sink drain in basement Mar 13, 2017
Plumbing Forum, Professional & DIY Advice How To Drain Utility Sink To Washing Machine Drain? Feb 9, 2017
