washerpan or drain
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Pabs, Oct 13, 2009.
  1. Pabs
    Pabs New Member
    Oct 10, 2009
    Moncton, NB (Canada)
    in my bathroom reno, I'm putting in my washer dryer (stacked) over tiled floor.
    for added safety do you guys recommend adding a drain on the floor or a washer pan?
    and, how is this tied in to the existing plumbing? can you hook that up the same as a sink or do you just run a line to your storm drain in the basement?
    Pabs
  2. dcelite
    dcelite Plumber
    Oct 5, 2009
    Los Gatos, CA
    Put a pan with a drain if you're going to do anything. When the hose breaks we hope most of the water goes into the pan. Out here we run the drain anywhere out of harm's way (outside, basement sump pump,, etc.). No need to plumb a trap and vent. Maybe put a screen on the outlet to keep insects or rodents out.
    DC
  4. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    If the washer is installed on finished floor it must by code have a pan that is either drained or has an alarm.
  5. Pabs
    Pabs New Member
    Oct 10, 2009
    cool, will do... that and I'll change the hoses every now and again... get them before they fail!
    thanks
  6. jadnashua
    Install a single handle shutoff with hammer arrestors so you'll be more likely to actually shut the water off when you are not actually running the WM.
Similar Threads: washerpan drain
Plumbing Forum, Professional & DIY Advice New P Trap drains very slowly. Tuesday at 6:39 AM
Plumbing Forum, Professional & DIY Advice Best way to remove this faucet drain? Monday at 9:32 AM
Plumbing Forum, Professional & DIY Advice Bathroom sink drain gurgles going down. Sunday at 1:49 PM
Plumbing Forum, Professional & DIY Advice Recommended rough-in height for kitchen sink drain? Sunday at 11:21 AM
Plumbing Forum, Professional & DIY Advice How to get hard plastic piece out of the drain? Sunday at 9:54 AM
