washer vent, is this ok?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Pabs, Oct 10, 2009.
  1. Pabs
    Pabs New Member
    Oct 10, 2009
    Moncton, NB (Canada)
    hi all
    new to this forum... been looking arounf and it seems lkke there's lots of good advice here
    here's my situation. I'm in the middle of a bahroom reno
    I'm doing the reno in order to put my washer and dryer on the main floor bathroom.
    This was the existing plumbing .
    [​IMG]
    I would like to tie in the washer to this system. is branching into like the pic below ok? can they both share the same vent in this manner?
    [​IMG]
    if so, are there distance minimums/maximums? can I put the inlet for the washer directly below the inlet for the sink? does the height of the washer inlet need to be at a certain height relative to the sink? etc
    thanks for taking the time
    Pabs
  2. jadnashua
    Note I'm not a pro...technically, since the WM T's into the pipe below the sink, it isn't a vent. You should be able to move it up and use the proper x fitting. Note, the WM drain line needs to be 2", and the sink's line may not be. There's probably some other things involved...wait for the pros. For power, code normally requires a dedicated circuit for the WM, but since it is in a bathroom, that might have to be a GFI. Not sure about that, either, but something to look into.
  4. Pabs
    Pabs New Member
    Oct 10, 2009
    makes sense,
    this would be a better design I think.
    [​IMG]
    the washer drain has to be 2 ...but the sink is only 1 1/2" correct?
    if hte WM drain has to be 2" then I won't have a choice but to make the whole thing out of 2" pipe I guess....right?
    Pabs
  5. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    This configuration is fine as long as the drain is 2 inch up to the lav drain. The vent above the top tee needs to be 1 1/2 inch. It is a simple wet vent configuration (the section between the W/M drain and the lav drain serves as both the drain for the lav and a (wet) vent for the W/M.
  6. Terry
    Aug 17, 2004
    [​IMG]
    It depends on the inspector and the local code.
    The picture above will pass anywhere.
    Or you could wet vent a lav, above the washer in some areas if you leave the pipe 2" until the 2 x 1.5 x 1.5 santee.
    The 2" pipe allows wet venting in that case.
  7. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    It does depend on the inspector and your adopted code. IPC now wants washers dumped into a 3" stack or main.
  8. jimbo
    jimbo Plumber
    The UPC does allow connection as shown in your second diagram ( washing machine vented). The trap must be located between 6 and 18 inches above the floor. Length of standpipe must be between 18 and 30 inches.
    In your first diagram, the WM is wet vented which is not allowed. Wet venting is limited to 1DFU and 2DFU fixtures. WM is 3DFU. Only exception is that a single bathroom group may be wet vented.
  9. Pabs
    Pabs New Member
    Oct 10, 2009
    6 inches, is that done so that you can get at them and clean them out if needed. I assume that's what's it's for.. .can't really figure out why the 18 inch limit though??
    when you say length of standpipe between 18 and 30 do you mean the lenght before it reaches the p trap? you are not talking about the overall height of the floor correct? and, just tobe sure, when you speak of the standpipe you refer to the pipe the drain hose goes into correct?
    are there any restrictions as to where I can put the connections in reference to one another? in the image below, do the distances C,D and E have an restrictions?
    i'm working with limited space, so if I'm able to put them close together that would be great..
    [​IMG]
    Pabs
  10. jadnashua
    I think that distance C should be enough to go 6" above the flood plane of the sink, or 42", whichever is higher to make the connection.
  11. Pabs
    Pabs New Member
    Oct 10, 2009
    6" above the sink line or 42"...
    what's with the 42? that would be 42 from the T? why o high?
    I can swing 6 above... 42 woul be pushing it given the space I'm working in
    Pabs
  12. Runs with bison
    Runs with bison Member
    Aug 23, 2009
    Midwest
    Seems like overkill with the new lower volume clothes washers becoming common. My front loader uses 12 gallons/load vs. 44 gallons/load in my old top loader. Are they going after a foaming issue? In engineering design 2" is good for about 8 gpm for self venting flow.
  13. hj
    wm
    Your original second drawing is one way I have been installing washing machine drains for decades. The third drawing is overkill, and does NOTHING to improve the drainage.
  14. jimbo
    jimbo Plumber
    The tie in for the vent must be 6" above the flood rim of the any fixture on the line. That is usually just taken as 42" above the floor. The sink might only be 32" high, but you would have to be 6" above top of the washing machine drum also.
    The length of standpipe is the pipe up from the trap.
  15. Pabs
    Pabs New Member
    Oct 10, 2009
    you mean this one?
    [​IMG]
  16. jeffeverde
    jeffeverde Member
    Sep 21, 2009
    L.A.
    I assume that last stretch of supply line is PEX? Why the foam wrap on the PEX but not the copper?
  17. yesterdayze
    yesterdayze Programmer / Engineer
    Oct 12, 2009
    Vermont
    Normally I would think you would need that air vent connection to avoid that being a wet vent since you typically only want to do that with say a sink, shower toilet setup, and even then....
    Even if it isn't needed by code where you are, it will still often make a difference in how much fun gurgling noises and exciting smells you get coming up out of the washer pipe after someone fills the sink to the top then pulls the plug and the water passing by pulls all the water out of the washer drain line trap. So the 10 minutes and 7 dollars worth of material may be worth just doing it.
    My house was setup just like your original second picture and every once in a while we would get some real charming smells after the sink had been filled up then drained. I added an air vent like you have in the third picture (though it connected higher up) and no more issue.
    *JUST OPINION, I am not a plumber, just diy'er - I differ to the experts ;)*
  18. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Terry's photo would be the correct way to go about it and will indeed pass just about anywhere with the exception that the IPC would now make you run 3" up to where the washer dumps in. Personally I think it's overkill and I would like to see the documentation of problems that have caused them to make that amendment. Then again it could be because the plastic companies are not selling enough 3 x 2 san tees :rolleyes:
  19. jadnashua
    While the newest WM front loaders use less water by far than the older top loading ones, they tend to dump that water out faster so there's a chance of a backup if you don't go bigger. Depends on how many bends, and what else may drop into that waste line if you'd have a problem; but, if it is big enough, it shouldn't matter. Yes, the hose isn't all that big in diameter, but the dynamics of a pumped verses gravity flow can make a big difference.
  20. hj
    Dwv
    NO. The lower one in the original posting with the washer into a sanitary tee in the riser.
  21. Pabs
    Pabs New Member
    Oct 10, 2009
    but doesn't that create a wet vent? I thought wet vents were not allowed in most cases...
    Pabs
Similar Threads: washer vent
Plumbing Forum, Professional & DIY Advice Moving kitchen sink and dishwasher, vent question Sunday at 6:24 AM
Plumbing Forum, Professional & DIY Advice Venting madness: Adding a second washer, moving one. Feb 16, 2017
Plumbing Forum, Professional & DIY Advice Please verify my proposed re-venting/draining for washer Dec 9, 2016
Plumbing Forum, Professional & DIY Advice Adding a Shower, Washer Box - Is this Waste & Vent Layout Correct? Jun 22, 2016
Plumbing Forum, Professional & DIY Advice Is this setup ok? Wet Vent/Washer/Utility Sink Nov 23, 2015
