Washer supply valve VS boiler relief valve
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by eddie-o, Aug 18, 2013.
  1. eddie-o
    eddie-o New Member
    Aug 18, 2013
    California
    Washer supply valve VS boiler drain valve
    Is there any problem in using a boiler drain valve as a supply valve for a clothes washer?
    It seems to be the only 1/4 turn valve readily available in my area that has the configuration I need; male, 1/2", near 90 degrees with the handle accessible (top) after installation.
    The visible difference is in the amount of threads available to the hose connection - three as opposed to five or so for the normal hose bib connection.
  2. DaPlumma
    DaPlumma New Member
    Dec 29, 2010
    Houston Texas
    When you say boiler relief valve what comes to mind is a temperature / pressure relief valve. What exactly are you trying to do. Connect your washer hoses.
  4. eddie-o
    eddie-o New Member
    Aug 18, 2013
    California
    DaPlumma -
    Please see the revised post. I should have said boiler drain valve.
  5. hj
    I purchase a washing machine box valve and then remove the valve from the shank and screw it in to the shank inside the existing box. Usually boiler drains are too large to screw/turn inside and/orl give room to operate the handle.
  6. eddie-o
    eddie-o New Member
    Aug 18, 2013
    California
    Thanks HJ. Though I installed prior to your post and went with the boiler drain valve... sure enough it was a bugger of a tight squeeze getting the valve in there - but made it with minor modification to the existing box (had to break one side out). :mad:
    I appreciate the sharing of your experience and taking time to post a reply!
Similar Threads: Washer supply
Plumbing Forum, Professional & DIY Advice Help sizing kitchen sink/washer/dishwasher water supply Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Dishwasher Supply Line - Hot or Cold? Aug 29, 2016
Plumbing Forum, Professional & DIY Advice Plastic or flexible dishwasher supply line Aug 13, 2015
Plumbing Forum, Professional & DIY Advice Reuse dishwasher copper supply line? Jun 29, 2015
Plumbing Forum, Professional & DIY Advice How many blown dishwasher supply lines do you see? Jun 26, 2015
