Washer stuck to copper pipe
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bertie, Aug 21, 2009.
  1. bertie
    bertie New Member
    Aug 21, 2009
    Hi
    We are trying to fit a plastic speed fit elbow 15mm onto our water pipe in our bathroom in order to connect a new shower unit to it. However we cannot remove the old copper washer used with the existing fitting :? - (I think it's called an adaptor?)
    We cannot use the existing fitting as we have had the walls plastered & re-iled (they needed it!) & this has resulted in less space between the shower unit & wall. The speed fit connector gives us the extra centimeter we need to get the shower back on for a perfect fit!
    We have tried everything to get the washer off but to no avail, any advice offered would be greatly appreciated.
    Thanks
  2. hj
    washer
    Depending on what you call a "washer", it could be a ferrule in which case you need a "ferrule puller" to extract it.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    A picture would help. Your use of the term "washer" may be inaccurate.
  5. jadnashua
    Assuming you are talking about a ferrule used in a compression fitting, the ferrule puller should work. It's sort of like a gear puller, they come in various sizes.
  6. bertie
    bertie New Member
    Aug 21, 2009
    Further info
    Hi
    After some more internet research I've found out that it's a compression ring & nut, & the nut is stuck, it seems like a common problem, but I couldn't find any info before as I didn't know the correct terms!!
    So I think a puller would be the answer, hopefully, thanks for posting back
  7. Gary Swart
    Sep 1, 2004
    Yakima WA
    Tools like this puller are fairly easy to find in rental stores in the US. I infer that you are not in the US since you are using metric sizing. You might shop a bit more and see if you can find a brass fitting instead of the plastic.
  8. hj
    ferrule
    Another problem might be that ferrule pullers usually only come in the size to remove 1/2"-5/8"" ferrules and you may have a different sized copper tube.
Similar Threads: Washer stuck
Plumbing Forum, Professional & DIY Advice Washer sub assembly stuck in frost free sillcock Apr 27, 2014
Plumbing Forum, Professional & DIY Advice Pipe Snake stuck in dishwasher drain Jan 6, 2011
Plumbing Forum, Professional & DIY Advice Bathroom sink faucets: ceramic cartridge vs. washerless cartridge;PVD nickel vs regular Saturday at 5:58 PM
Plumbing Forum, Professional & DIY Advice Moving kitchen sink and dishwasher, vent question Feb 19, 2017
Plumbing Forum, Professional & DIY Advice Venting madness: Adding a second washer, moving one. Feb 16, 2017
