Washer outlet box
jwalters2112
Rochester, NY
Father in law removed his old wash sink and put in a washer outlet. He tapped in that same drain line..on that drain line immediately behind the wall also has a bathroom sink going into it. He never trapped the washer drain...it goes directly in the drain line..is this ok? The wall is closed up and all I have access to is where the drain goes into the crawl space...can I place a trap right at that point?
PRObably NOT, from your description of what he did, but it really depends on how he installed the pipe. You probably going to have to open the wall again.
jwalters2112
Rochester, NY
Thanks HJ
Obviously he has no picture so I made a quick diagram based off what he explained..said it was really tight in the stud where he has the washer box. I guess if I can't place the trap on the line, can I put a 45 elbow and bring the pipe into the crawl space and then just trap vent and make a dedicated drain line to the washer?
