txremodel1
Looking for some guidance here... would value and appreciate any and all input.
Have a 1970s slab ranch house with cast iron DWV. Washer drain overflows from standpipe from time to time. Not consistent and I suspect it is from normal build up... lint, etc. P-trap must be sub-grade below the slab, because it's not in the wall. I can remove the fernco and check or will check with my small diameter snake. No visible vent pipe at location of washer drain.
I also understand that 2" CI is likely to "close up" or become restricted when compared to 4" CI? Might be my situation. Wish that I had a drain camera and I am considering purchasing a cheaper one for this exact reason.
Anyhow, doing a major remodel on this side of the house and do not want to deal with this overflow issue in the future. Considering the following options -
I am sure there are other options and this is why I came here for advice. If option #3 is feasible and meets code, it seems that it would be the quickest solution?
Thoughts? Thanks in advance.
1) Do nothing but monthly or quarterly "maintenance" and snake the drain to clear any obstructions.
2) Use rotary hammer to replace 2" CI with PVC. A lot of work, but might be the best option? Slab is not post-tension. Will be doing similar work for a master bath and shower.
3) Provided it meets code, there is a main 3" CI stack that is located on the other side of the wall - see picture. This is the master vanity. Approximately 58" from center of current washer drain to center of stack. Could swap dryer and washer locations, putting the washer drain even closer to the vent stack. I assume that I could then cap off the original 2" CI washer drain.
