Washer drain pipe blocked
Discussion in 'Drain Cleaning' started by carimwc, Oct 16, 2006.
  1. carimwc
    carimwc New Member
    Oct 16, 2006
    While doing laundry tonight, I discovered that my washer was not draining properly and spewed water all over the floor. The drain hose was fine and we drained the washer by using buckets. The drain pipe seems to be blocked.
    We poured water down the drain and some of it went down but it started to back up. Short of calling a plumber, is there anything we can do to solve this?
    We've only been in this house for 2 months and it was built in 1970.
    Many thanks.
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Get a drain cleaning machine and rod the drain. The same thing a plumber would do if you call them.
  4. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Call Roto-Rooter. If you don't have experience using an electric snake, you could get hurt.
  5. Jeff1
    Jeff1 New Member
    May 24, 2006
    So Cal
    I had a similar problem with my 1965 house. An additional problem was my drain was 1 1/2 inch so even after clearing it, it still backed up with my new washer. The solution was to replace it with 2 inch.
Similar Threads: Washer drain
Drain Cleaning Bi-yearly washer drain clogged - HELP ! Apr 12, 2013
Drain Cleaning Floor drain backup from washer Sep 17, 2007
Drain Cleaning Dishwasher/Sink/Disposal Jun 2, 2016
Drain Cleaning Double Sink Island w/ Dishwasher Clog Apr 15, 2014
Drain Cleaning The ole washer backup Feb 22, 2014
