Washer drain and sink in basement
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rosem637, Feb 22, 2013.
  1. rosem637
    rosem637 Member
    Jan 1, 2013
    Michigan
    Want to setup the washer/dryer/laundry sink in my basement. Does the below setup look good to go?
      File size:
      18.7 KB
      307
      File size:
      28.2 KB
      496
  2. rosem637
    rosem637 Member
    Jan 1, 2013
    Michigan
    or drain sink into the washer branch
  4. rosem637
    rosem637 Member
    Jan 1, 2013
    Michigan
    what about this get rid of the laundry tub and put in a toilet and lav sink. Use the lav drain as a wet vent for the toilet??
  5. Hammerlane
    Hammerlane Member
    Oct 22, 2011
    In the picture abovein post #3 why do you have the toilet drain running toward the west-southwest into the washer branch then into the main when the shorter distance is to the southeast directly into the main.
    attached a compass rose for the navigationally challenged
  6. hj
    How many more possibilities can you come up with? They are all "proper", but not necessarily the "best" designs. In fact, there are MANY ways it could be done properly, not just the ones you show, so it is a personal preference how you do it. The compass rose is immaterial in an isometric drawing, unless it is also "skewed" to show the pipe direction, The angles are mostly 30 and 60 degrees so there is no "southeast" diriection.
  7. rosem637
    rosem637 Member
    Jan 1, 2013
    Michigan
    because I can use the lav sink as a wet vent. if I go to the SE as you say with the toilet drain I still have to vent the toilet.
  8. rosem637
    rosem637 Member
    Jan 1, 2013
    Michigan
    yes many different ways to do this
Similar Threads: Washer drain
Plumbing Forum, Professional & DIY Advice how to properly do drain for the washer Mar 23, 2017
Plumbing Forum, Professional & DIY Advice Drain design with stack in middle of 2 sinks + washer Mar 15, 2017
Plumbing Forum, Professional & DIY Advice Washer and sink drain Mar 6, 2017
Plumbing Forum, Professional & DIY Advice Washer drain vent Mar 4, 2017
Plumbing Forum, Professional & DIY Advice Washer drain pipe Feb 14, 2017
