Was the right knockout hole used in this case
Discussion in 'Electrical Forum discussion & Blog' started by DIY, Apr 3, 2009.
  1. DIY
    DIY Member
    Dec 24, 2006
    Florida
    This exsisting metal box that is in place on the inside of an exterior cinder block wall is 3"H x 2"W X @2-1/4"D. I had a receptacle installed in what was once a with a vacant box.However, In this box it has two knockouts top and bottom of box and one knockoout in the back middle of box. The other outlet boxes in this house are of the same size and kind all utilize one of the top or bottom knockout holes for wire access to receptacle. The 4 knockouts for top (2) and bottom(2) of box measure 5/8" and the knockout in middle back of box measures 3/4". Are these knockout holes for install options,or only to be used with specific wire size applications?(wire used in this case was 12-2) The electrician i hired to do this is good and well established ,but gave me a short quick answer which kept me wondering..hence my reason for asking the pros here.
    The knockout access hole that was used with the 12-2 cable was one of the top two 5/8" with a cable clamp.
    Thanks to all!
  2. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    Too much information.
    What you want to know is "Is it OK to use any KO in a j box?"
    Answer: yes
  4. hj
    Ko
    The one in the rear should have been closer to 7/8" for use with a connector of some kind with a 1/2" pipe thread. If the others have cable clamps then they were for use with your Romex.
  5. DIY
    DIY Member
    Dec 24, 2006
    Florida
    knockouts
    Yah...laughing I went overboard on the info. Are knockouts ok to use....laughing j/k. Thanks for the replys 220/21 & hj.
  6. hj
    ko
    Knockouts are okay to use, IF the proper connector is used in them, if needed.
Similar Threads: right knockout
Electrical Forum discussion & Blog One right way to run electrical Jun 5, 2014
Electrical Forum discussion & Blog 1 circuit/2 gang 3 way switches- Does this look right? Apr 17, 2014
Electrical Forum discussion & Blog Torque (getting it right) May 10, 2010
Electrical Forum discussion & Blog 2 way switch not working right Jan 1, 2010
Electrical Forum discussion & Blog Right controller??? Mar 27, 2008
