warm water from the cold faucet?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bigelee, Jun 11, 2009.
  1. bigelee
    bigelee New Member
    Jun 11, 2009
    I am renovating an apartment on the top floor of a four story house. I installed a single handle shower mixer and a separate tub (which has a two handle and spout layout). I turned on the water to the apartment and everything seemed fine, but now there is warm water in the cold line in all of the apartments. Does this mean that the shower body is bad? did I connect it wrong? is there a backflow valve that I missed or something? Or could this be something worse and there are crossed hot and cold lines somewhere? What do I do to fix this-help!!
  2. faucetman886
    faucetman886 DIY Junior Member
    Oct 22, 2008
    retired accountant and blogger
    near Atlanta
    Is the water in the toilet tank when it refills also warm? Is there a central water heater for all of the apartments? If yes to both you could have a over heating HW heater that the T&P valve isnt functioning. I have run across this 3 times in the last 3 weeks on various forums. Potentially very dangerous.
  4. jadnashua
    Some single-handle valves can fail and provide a cross-over. Try (if you can) turning the handle all the way to one side while off and see if it makes any difference.
  5. bigelee
    bigelee New Member
    Jun 11, 2009
    I think it is a faulty valve- makes sense?
    Thanks for the responses- the shower mixer in the new apartment is a Kohler, so I called them and they are sending me a new valve. I will replace it and post if that was the problem- let's hope so!
  6. bigelee
    bigelee New Member
    Jun 11, 2009
    well, that didn't work...
    I replaced the valve in the shower- single handle mixer- I assumed this was where the lines were crossing, but no go. The water coming into the toilet is fluctuating between hot, warm and cold. Could it be that the hot water heater is too hot and is somehow pushing the hot water through the valve anyway? HELP!!!
  7. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Is there a mixing valve somewhere in the line?
  8. bigelee
    bigelee New Member
    Jun 11, 2009
    there is the mixer for the shower, but it is brand new AND I replaced the valve with out solving the problem. I am now turning the temp way down on the hot water heater (it was all the way up) to see it the hot water pressure was too high and was forcing its way into the cold (I assume through the shower mixer). The tub has two handles which are off, so that isn't it, right?
  9. Fuzzy2
    Fuzzy2 New Member
    Jul 14, 2009
    It might be something totally unexpected
    OK, I finally had to come out of lurk mode to reply to this one.
    Forty years ago, when I was in school in Cambridge MA, I lived in a top-floor
    apartment in a four story building which was some ninety years old at the time
    and I believe is still standing.
    Every morning we were treated to scalding hot water from the cold water faucet in the kitchen. I eventually worked out (by inspection) what was going on: the hot water heater was in the basement with a recirculation pump, and both the hot and cold water pipes were routed up through an interior light/air shaft to the attic of the building and then down to the apartments on each floor. But the pipes, of course, were galvanized, and held by common metal clamps all the way up and across the attic, so the recirculating hot water warmed the standing cold water in the pipes to the kitchen which weren't used overnight. The bathroom fixtures were less susceptible, because they were in more use during the night.
Similar Threads: warm water
Plumbing Forum, Professional & DIY Advice Supplying warm water to RO Dec 8, 2016
Plumbing Forum, Professional & DIY Advice Lukewarm cold water...help me solve the mystery! Aug 15, 2016
Plumbing Forum, Professional & DIY Advice Luke warm water from a hot water angle stop for a faucet Dec 30, 2015
Plumbing Forum, Professional & DIY Advice Why does my cold water turn warm? Delta Shower Valve Mar 28, 2015
Plumbing Forum, Professional & DIY Advice Warm water mornings on cold line for 30 secs.... Feb 22, 2015
