Wanting to move toilet back against wall
Chris McA
Brookline, Massachusetts
We have an old small bathroom and the toilet slouches forward on a 14" rough. I thought if we put a toilet with a 12" rough it would take it back towards the wall but read that will put it forward 2". Is there anything I can do to move the toilet back and leave more space in front of the toilet?
Most 12" rough toilets set out from the wall between 1/2" and 1"
With a 14" rough, add two more inches behind the tank.
Most 14" toilets use a 12" bowl and a thick tank, which leaves the bowl sticking into the room, but closes the gap behind the tank somewhat.
TOTO does make some of their bowls that allow a 2" offset closer to the wall, but only in their elongated bowls. It does shift the sitting position back those two inches.
https://terrylove.com/wc/unifit.htm
They manage this by using different size floor adapters. The center one is for a 12" rough.
Left is 10" and right is 14"
