Want to add Shower
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by joelshattles, Oct 12, 2004.
  1. joelshattles
    joelshattles New Member
    Oct 12, 2004
    more computers
    lawrenceville, ga
    Have bathroom stubbed only for sink and toilet. Would like to add shower stall.All this sits on a concrete slab, but is on corner with two outside walls. What are options for stubbing in the shower ? Also, this is on septic system and house is wood frame/cedar, i.e., easy to go in/out of structure.
  2. e-plumber
    e-plumber DIY Senior Member
    Sep 1, 2004
    New York
    Under normal conditions, the cement floor would need to be opened to expose the 3" or 4" toilet drain to tie in the proposed shower drain, venting is an important consideration as well.
  4. joelshattles
    Oct 12, 2004
    more computers
    lawrenceville, ga
    Thanks !
    I appreciate the quick response, and also that this isn't necessarily a week-enders choice of jobs to take on! Can you recommend how I should go about locating a reputible sub/con to take on this type of job? How much pre-planning should I undertake prior to calling in a pro ? I could measure out the complete area and create a diagram of how we hope the finished bathroom will be laid out, recognizing that the positioning of the shower will be affected by the drain and vent. I live in the Snellville/Lawrenceville Georgia area.
    Again, thanks a lot for the quick response.
  5. joelshattles
    Oct 12, 2004
    more computers
    lawrenceville, ga
    Another Question
  6. Deb
    Deb Plumber
    Sep 5, 2004
    Idaho
    Deb
    Do you have family or friends that have had plumbing work done and were happy with the job? That is usually about the best recommendation. Plumbers that do a good job at one location are likely to do the same on the next job--this is their work ethic. You may want to get a couple of bids.
    I would do no preplanning. The plumber will most likely want to look at what you have anyway and exactly where existing plumbing is. It is really tough to do any real planning from a diagram. You can tell the plumber where you would like the shower and he can tell you how tough that will be (few things are impossible, some things just cost more than others). And, you really have some leeway, since the trap arm can be 5'. When you decide on a plumber, he can tell you where the concrete will need to be removed and how much dirt will need to be dug out.
    Deb
    The Pipewench
Similar Threads: Shower
Plumbing Forum, Professional & DIY Advice Shower cartridge Today at 8:34 AM
Plumbing Forum, Professional & DIY Advice ProPEX shower valve instalation Yesterday at 10:13 AM
Plumbing Forum, Professional & DIY Advice Chipped shower tile....what to do help!! Monday at 6:09 PM
Plumbing Forum, Professional & DIY Advice Installing new shower rough-in. Remove more drywall? Feb 15, 2017
Plumbing Forum, Professional & DIY Advice Shower venting details/ dry run Feb 15, 2017
