wall sconce rough-in height?
mrang@neo.rr.com
is there a typical rough-in height for the junction box for a wall sconce. i realize there are many styles and we haven't selected our fixtures yet. thanx
JWelectric
Electrical Contractor/Instructor
North Carolina
One factor that will be used to determine the height is the building code.
The building code calls for no less than 6' 8" of head room.
This will be imporant if the fixture is being installed in a hall or stairwell as the fixture can not encroach on the required width of these areas.
Chris75
Electrician
Litchfield, CT
Bath sconces I always cut in after the fact, but hallway and etc I will go with 60-66" AFF... usually 66",
You often don't want to see the bulb (unless it is a decorative one), so that may influence the installed height.
