Wall placement around shower drain hole
Discussion in 'Shower & Bathtub Forum & Blog' started by homenut, Jun 2, 2005.
  1. homenut
    homenut New Member
    Jun 2, 2005
    Hi all,
    I am finishing my basement and adding a bathroom. When the house was build, the builder placed sink, toilet, and shower drains into the cement floor. The shower floor drain is in a square hole about 15"x15". There is simply a 2" PVC pipe sticking in from the side of the hole (capped). I will be hiring a plumber to do all the connection work with the shower. However, I want to frame my walls around the future enclosure now. The problem is, I don't know what to use as a reference for these walls. I have the dimensions of my shower unit which are based off its drain.
    Will the drain in my cement floor end up being placed in teh center of the 15x15 square hole? Should I assume it will end up some distance away from teh 2" pipe?
    Also, I do not see any vent associated with any of the floor drains? The only reasonable place to connect a vent would be to the 2" pipe for the sink since this sticks up about 24 inches. Is this normal or should I plan to add a vent to the shower drain somehow? Again, this is only to figure out how to place my stud walls.
    Thanks! :confused:
  2. jadnashua
    I'd dig down in that hole a little to see if there is a trap installed. If there is, then the pipe would be exctly centered around your shower pan. My unprofessional opinion.
  4. John Bridge
    John Bridge Mudmeister
    Sep 4, 2004
    Owner, John Bridge Services
    Houston, Texas
    My unprofessional opinion is that the location of the drain is adjustable. That's why they left the 15x15 opening. :)
  5. Terry
    Aug 17, 2004
    John's right.
    The 15"x15" block out is used for the p-trap connection.
    Since the location needs to be exact, the trap is installed by the plumber that is setting the pan.
    And of course, you won't know the exact center until the walls are framed for it.
  6. homenut
    homenut New Member
    Jun 2, 2005
    Thanks
    Thanks for your help. THe hole is open and unfileld, definetely no P-Trap installed yet. I will build the walls so that the center is at least a 6" arc away from the pipe that comes in from the side to allow space for the P-Trap and some adjustment (or I may just buy one at HD and fit it on there with no glue for the time being).
Similar Threads: Wall placement
Shower & Bathtub Forum & Blog Drop in acrylic tub placement against wall - would resemble alcove? Aug 5, 2013
Shower & Bathtub Forum & Blog Replacement mixer valve body too big for wall space. Sep 17, 2007
Shower & Bathtub Forum & Blog Lustrolite shower wall covering Feb 20, 2017
Shower & Bathtub Forum & Blog Cutting into block wall for shower water supply Feb 14, 2017
Shower & Bathtub Forum & Blog Faucet wall tubes and wall tube escutcheon is not water tight Feb 9, 2017
