Wall Mounted Toilet
Terry, et.al.
Thanks for your replies.This is for our home, built in 1968, it has 3 Case wall hung toilets and 1 Kohler wall hung. They are attractive, have outstanding operation and they are easy to clean around. We are remodeling two bathrooms and the simplest , least work and lowest cost, is to get the same kind in beige or white. Simplest, because the carrier is in the wall and Case and Kohler types require little or no modification. Michigan allows resale of these fixtures , so it is no problem. in the past we have found one new Kohler and one used excellent Case. If we can not find these , we will look at the specs on the Crane-Rexmont and Am. Std.-Glenwall, they might be the next best solution. Any further comments are appreciated and we thank you for the leads on these others.
Dennis C.
