Wall mount Faucet Soldering
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ChrisNJ, Feb 24, 2007.
  1. ChrisNJ
    ChrisNJ New Member
    Feb 24, 2007
    NJ
    Hi Folks!
    I'm brand new here and I have a question.
    I am trying to solder this fitting:
    [​IMG]
    to a brass in-wall faucet manifold and I can't get the solder to flow. I'm using a MAPP gas torch, flux, and 95 5 solder. I clean the fittings and the manifold like normal, flux 'em, heat the fitting not the manifold, and it just wont go :mad:
    What SHOULD I be doing that I'm not. Any input would be most appreciated. Thanks!
  2. Terry
    Aug 17, 2004
    What kind of metal is that?
    You can solder brass and copper.
  4. ChrisNJ
    ChrisNJ New Member
    Feb 24, 2007
    NJ
    Actually, upon closer examination, it may be brass. It has a chrome finish to it though. Is that messing everything up?
  5. Terry
    Aug 17, 2004
    I didn't think you could solder to the chrome plating.
  6. ChrisNJ
    ChrisNJ New Member
    Feb 24, 2007
    NJ
    Any suggestions then? It is a sweat type fitting? Is there an alternative method? What can I say, I'm new at this.
  7. hj
    chrome
    You have to remove the chrome where you want to solder it. But it might be a lot easier just to buy a copper reducer like that one. What is the purpose of the fitting?
  8. ChrisNJ
    ChrisNJ New Member
    Feb 24, 2007
    NJ
    Well, I have an assembly for a Belle Forret wall mount faucet. I need to join 1/2inch copper from the basement to the assembly. The pipe won't line up. Now, I've decided I'm gonna try and bend the pipe comin up from the basement with heat and ten just use a regular old copper union, rather than that funky thing I was gonna try.
    Heating bending copper just a little bit is ok, right? I'm learning as I go :-D Any input would be great.
  9. RioHyde
    RioHyde Plumber
    Sep 24, 2004
    Cincinnati, Ohio
    While I have seen hard copper heated up to red hot then bent just as you would soft copper, I personally find it to look like a hack job. I would just get a couple of 45s and/or a 45 and street 45 to offset the copper where it needs to be.
    As far as soldering that fitting, its like HJ said, you have to remove the chrome from your soldering surface. Anyone who's worked in Kentucky and has used chromed traps can testify to this.
    Good luck
  10. ChrisNJ
    ChrisNJ New Member
    Feb 24, 2007
    NJ
    45s
    That sounds like a plan. I hope the Lowes around here is still open. Once I get this thing sweated and in there, I'll take a cople of pics so you guys can tell me what I should have done . . . hahahahah. Thanks! :)
  11. Racer814
    Racer814 New Member
    Dec 24, 2006
    just make sure you are plumb and level coming out of the wall....
    check it two or three times.....any variance will be magnified when you install the trim...and give it good support
    good luck
  12. ChrisNJ
    ChrisNJ New Member
    Feb 24, 2007
    NJ
    Racer - My guess is you've done this before. This is my wife an I's first remodel project, and she really wanted a wall mount faucet so I said "ok, I can do it". Hopefully, I will be able to make it happen :)
    Any other helpfull hints you could provide?
  13. Racer814
    Racer814 New Member
    Dec 24, 2006
    you can do it...they look great.
    mostly just make sure it is level and plumb....and supprted well....you want it to feel rock solid!
    just take your time:)
Similar Threads: Wall mount
Plumbing Forum, Professional & DIY Advice How can I correct the Wall Mount faucet depth? Jan 25, 2017
Plumbing Forum, Professional & DIY Advice Advice on half bath plan for basement with wall mount toilet Sep 15, 2016
Plumbing Forum, Professional & DIY Advice Wall mount toilet on exterior wall/vent question Nov 30, 2015
Plumbing Forum, Professional & DIY Advice IKea wall mounted bathroom vanity install problem Nov 9, 2015
Plumbing Forum, Professional & DIY Advice plumbing for wall mounted shower Sep 1, 2015
