Wendi
Hi, please help me!
We have a Proflo PF1705HEWH wall hung toilet with a Zurn Z1212 carrier. The plumber never worked with one before, and everyone we've talked with said they've never worked with one, either. He has two questions that he needs me to find the answer for (he's a friend, doing this as a favor).
http://content.zurn.com/web_documents/pdfs/installation/C31.pdf
The backside of the toilet is pressed against a neoprene gasket into the Zurn toilet flange and threaded coupling. That part hasn't been an issue (after learning about the neoprene gasket here on this forum--Thanks!).
The questions are with the middle section/Zurn:
1) Is there another gasket in addition to the O-ring inside the Zurn flange? It looks like there's another space for something...and the threaded couplings aren't meeting in the middle???
2) The actual point of connection between the threaded coupling and a 3" ABS waste drain doesn't fit. The 3" ABS drain is too small for the threaded coupling. How does he connect the 3" ABS drain pipe to the Zurn threaded coupling???
Not sure if this picture is helpful, but here's how the plumber explained it to me, so I could ask for help.
