Wall hung toilet gasket
Discussion in 'Toilet Forum discussions' started by Peggins, Oct 19, 2013.
  1. Peggins
    Peggins New Member
    Oct 19, 2013
    Maine
    I have a customer with an old Crane wall hung toilet that began to leak through the ceiling. It had a neoprene gasket and a lot of wax and had probably worked fine for decades. I've never had the joy of working on a wall hung toilet before but have heard that wax is a bad idea because it will eventually flow and leak. The problem is that when I re- installed the toilet with the only gasket (Zurn, 3/4 " thickness) I could get from my supplier it leaked. I cleaned everything very well and instructed the tenants to not use the toilet for 3 days, I know they complied. When I pulled the toilet again there was no glue on at least half of the flange, which I had applied liberally to the gasket as per the instructions. I had been a bit concerned about how far the gasket was recessed into the toilet so the second time around I measured. The flange of the carrier protrudes from the wall 1/8" and the gasket recedes into the toilet 1/4" . Bingo as to why I failed, and very glad I told them to wait on repairing the already badly damaged ceiling.
    I found a 1 1/4 Zurn gasket, with no glue, would that work?
    Can I simply use two 3/4" with glue between the two gaskets?
    Do new wall hung toilets have a smaller recess and therefore the 3/4 gasket would work fine?
    Clearly the old Crane is not low flow, if I sold them a new toilet what would you recommend?
    Thank you, I've been a lurker here for years and have learned a lot. Hoping you can help me solve this problem.
  2. Terry
    Aug 17, 2004
    1/8" from the wall is too short.
    They do make a wall mount rated wax ring.
    We use the foam rubber washer, and we test them before we leave the job. Even with the glue.
    I used to work in a bicycle shop, and it looks like the same stuff I patched inner tubes with.
    Oatey reinforced wax ring spec
    http://www.oatey.com/doc/Urethane_Reinforced_Wax_Ring.pdf
    We have been replacing with the American Standard Glenwall.
    Gerber now makes a replacement too in the Maxwell line.
    [​IMG]
  4. Peggins
    Peggins New Member
    Oct 19, 2013
    Maine
    Thanks for the fast reply. I tried to adjust the waste horn, but after years of sitting there it would not budge, so I'm stuck with the dimensions that currently exist.
  5. Terry
    Aug 17, 2004
    When re-hanging the bowl, it's easier if you thread the top cap nuts first. You can tighten three nuts down snug, the forth should be left hand tight. It's the forth nut that can crack a bowl.
  6. hj
    convention is that the two bottom and top left bolts are tightened, and top right one is hand snug. You do not have "glue" the gaskets in place. The weight of the toilet secures them, have enough depth so it compresses the gasket and makes a good seal.
Similar Threads: Wall hung
Toilet Forum discussions Aquia wall-hung bowl, TOTO tank required? Feb 3, 2017
Toilet Forum discussions Wall Hung Recomendation Nov 13, 2016
Toilet Forum discussions Replacing a wall mounted - what do you think of Toto's wall hung toilet? Mar 20, 2016
Toilet Forum discussions Wall hung toilet leaks when flushed Jan 20, 2016
Toilet Forum discussions Wall-hung toilets Jan 17, 2016
