Walk-in Tile Shower help
Discussion in 'Shower & Bathtub Forum & Blog' started by tysbol584, May 7, 2009.
  1. tysbol584
    tysbol584 New Member
    Nov 26, 2008
    I am building a walk in shower. We are going to tile up the entire walls and the floor. For the walls should I drywall with green board then use cement board over the top of that? Or just use cement board over the studs?
    Thanks
  2. jimbo
    jimbo Plumber
    San Diego, CA
    cement board on studs. you need a vapor barrier ( 6 mil poly or 15 lb felt) under the cement board.
    johnfrwhipple likes this.
  4. jadnashua
    There are lots of ways to skin this cat, but Jimbo has you pointed in the right direction. There are alternatives that work well...two things, check out the Kerdi shower system at www.schluter.com and go over to wwwjohnbridge.com for help with your tiled shower using either conventional methods or Kerdi (and others).
  5. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Always follow local code for insulation and vapour proofing needs. Never use drywall in a shower build unless your looking to build it as cheaply as possible. I know some companies promote the use of drywall but I think this is to offset the cost of their membranes.
    Concrete Board - WonderBoard Lite my favourite.
    Good Luck.
Similar Threads: Walk-in Tile
Shower & Bathtub Forum & Blog Installing a walk-in tub from Costco Apr 16, 2016
Shower & Bathtub Forum & Blog Drain and faucet position for walk-in shower Oct 23, 2013
Shower & Bathtub Forum & Blog Walk-in bathtub reversed drain Nov 27, 2011
Shower & Bathtub Forum & Blog WEDI walk-in shower base construction Apr 3, 2011
Shower & Bathtub Forum & Blog Premiere Walk-In Tub Drain Nov 10, 2009
