wacked pipe
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by scott99, Feb 13, 2007.
  1. scott99
    scott99 New Member
    Feb 1, 2007
    okay, so I get my new therm mixer soldered in, out of the top port up about 6in a valve. no pipe yet on the output side. the valve has the plastic rough in depth extension install. the mixer has threaded ports.
    I'm on a ladder working on shower head fitting and while getting down I wack the plastic extension pretty hard with my knee.... I'm sure it flexed the pipe to some point, and now I'm worried that I stressed or fractured the joints and may get a leak. Its been under pressure for two days and so far so good.
    Is this something I should be concerned with and should redo that section, or just consider it stress tested and move on??
  2. Cass
    Cass Plumber
    Nov 12, 2005
    No....continue on.
  4. hj
    valve
    You probably did more damage to your knee than to the valve. If it is not leaking and you do not see any bent piping, don't worry about it.
  5. scott99
    scott99 New Member
    Feb 1, 2007
    thanks, those comments help put my mind at ease. three days, so far so good...
Similar Threads: wacked pipe
Plumbing Forum, Professional & DIY Advice How do I fix this vent cast iron pipe? Tuesday at 1:12 PM
Plumbing Forum, Professional & DIY Advice Bending 3/8" chromed copper supply pipe to toilet Monday at 8:27 AM
Plumbing Forum, Professional & DIY Advice Dumb, probably repeat laundry standpipe question Feb 16, 2017
Plumbing Forum, Professional & DIY Advice Plumbing leak on plastic pipe Feb 15, 2017
Plumbing Forum, Professional & DIY Advice PEX Pipe in attics? Feb 14, 2017
