Vinyl siding---should I remove the old shingles first?
Discussion in 'Remodel Forum & Blog' started by eastinway, Apr 6, 2009.
  1. eastinway
    eastinway New Member
    Jul 7, 2008
    Hi folks,
    Single female homeowner here with a question about vinyl siding my home..
    Currently I have wood shingles on the house (a small cape cod style home). The shingles on part of the home are cracked and worn so instead of painting again I'd like to just to put vinyl siding on the house.
    I have had several siding companies at the house for estimates, some want to remove the existing shingles, some don't. I realize there are labor costs involved to remove the shingles but the estimates are not bad.
    I have been told that removing the shingles would look better.
    I am confused.....Can someone tell me what I should do.....:confused:
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    By all means remove the shingles. Vinyl siding will follow the bumps in the wall and those shingles will cause lots of waves. The sheathing should be smooth and provide a nice surface to attach the vinyl. I would not even talk to an applicator who didn't want to remove the shingles. Removal should not be a major expense, they can peel them off very quickly.
  4. eastinway
    Jul 7, 2008
    Thanks Gary.....should they remove the roof shingles also?
    Thanks very much for your reply......I am getting a new roof and my question is: Some of the contractors say that they will go over the existing roof shingles and some would remove them.
    What does one do in this is the original roof, just faded and old. I am not liking the idea of leaving the old ones on. What do you think?
    My house is a small Cape Cod style looks like a doll house and easy to get around (repair wise)....I hope I don't get taken advantage of, price wise for this job. It consists of vinyl siding, new roof and building new side stairs (composite not wood).
    Need advice please,
  5. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Leaving the old ones on, is a short-sighted way to cut costs.
    Personally, I wouldn't hire anyone who proposed it.
  6. jadnashua
    It's safer to remove them since there could be some structural problems from past leaks that you wouldn't know about until they try to nail in the new ones and find the wood is all rotten. If the roof structure is solid, it is considered acceptable to install a second shingle roof over an existing one, but never a third layer. Depending on where you live, you may want to have them install an ice and water shield layer on the lower eave area and maybe roof valleys. This also works better if applied to the roof sheathing than the existing layer. If the current roof is cupped and there are missing shingles, dump it and start fresh.
    A tear-off is pretty quick, but watch out for nails - make sure they clean up well. A big magnetic roller is a good idea, you don't want them in the yard when you mow the lawn or in your tires.
  7. GregO
    GregO Member
    Oct 5, 2004
    I completely agree with the other posts = tear off the roof and siding wood shingles. Yes, both can be done without tearing off, but it will yield an unprofessional job. Tearing off will cost a little bit more, but will enhance every aspect of the finished job. Given your NE climate, Jim's recommendation for ice/water shield is the absolutely right way to go.
    Do it once, do it right. Greg
Similar Threads: Vinyl siding---should
Remodel Forum & Blog Vinyl Window Question: Ok for corners to buckle? May 14, 2015
Remodel Forum & Blog In-floor heat under vinyl flooring? Mar 4, 2013
Remodel Forum & Blog Residential vinyl window replacement: Fairfield 70 Series Oct 30, 2012
Remodel Forum & Blog Ultramaxx Fusion-Welded Residential Vinyl Windows May 25, 2012
Remodel Forum & Blog Fairfield 80 Series Residential Vinyl Windows May 10, 2012
