Vinyl siding for mobile home?
Discussion in 'Remodel Forum & Blog' started by goldenroadrunner, Mar 5, 2007.
  1. goldenroadrunner
    goldenroadrunner New Member
    Mar 5, 2007
    I am interested in some kind of exterior remodel for my 34 yr old mobile home. All of the windows leak air and/or water and the exterior is just remarkably ugly. I also need to replace the skirting. What would be the least expensive avenue? Moving isn't an option and painting it would just accentuate the negative.
    Thank you,
    Ginger
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    Material costs aside, your project could be quite a challenge. Where regular siding goes up a wall and terminates under an overhang, your metal roof simply folds over and is sealed and fastened to the top edges of your walls. Then, your windows are fastened on top of your existing siding, with no "brick mould" for J-channel and new siding to butt against and wrap around.
    To install 5/8"x4'x8' sheets of new siding material (or anything else that is thin) could be done relatively inexpensively if your windows were first pulled and someone could come up with a good plan for your roof edge ...
Similar Threads: Vinyl siding
Remodel Forum & Blog Vinyl Siding? Apr 13, 2012
Remodel Forum & Blog Aluminum or vinyl siding Apr 26, 2011
Remodel Forum & Blog Vinyl siding repair Oct 7, 2009
Remodel Forum & Blog Vinyl siding---should I remove the old shingles first? Apr 6, 2009
Remodel Forum & Blog Should I insulate attic first or install vinyl siding Jan 22, 2009
