Vinyl Fence Installation
Discussion in 'Remodel Forum & Blog' started by eastinway, Jul 7, 2008.
  1. eastinway
    eastinway New Member
    Jul 7, 2008
    Hi folks,
    I am a single female homeowner who is in the market to purchase a fence. My property has a small grass lawn between my home and my neighbors house. The property line falls in the middle of the lawn and there is a flat area which gently slopes to the edge of a rock wall.
    I have been getting quotes from several fence companies in my area. Most of these companies with the exception of one installs vinyl panel fences with a lattice top into the ground using cement as well as other materials to hold the posts in.
    I like the company that does NOT cement the posts only because I particularly like one of the styles of vinyl fence that they offer and have seen their work in my area which is quality.
    My question is.......should I be leary about going with a company that does not cement the posts into the ground. I am concerned about the fence toppling over or moving as the ground freezes and thaws.
    Any thoughts appreciated.:) Go Red Sox!
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I can not understand your reluctance to cement the posts. The cement does not have to come completely to the surface of the ground. If you are concerned about the stability of the fences as you say you are, then concrete is the only way to go. I'm sure there would be companies that would just bury the posts in soil if that's what you wished, but if it was my operation, I wouldn't take the job because when it leaned and sagged, it would not reflect well on my company. If anyone did take the job, I would expect them to require you to sign an agreement that you would have no free adjustments when the fence started to lean or sag.
  4. Gary Swart
    Sep 1, 2004
    Yakima WA
    Do you have any idea how much force will be against your fence in a windstorm? A rail fence would not be too bad, but a solid wall will be like a sail on a ship.
  5. eastinway
    Jul 7, 2008
    Hi Gary and thanks for your reply. I really want to have the vinyl panel fence installed with cement inside the posts as most of the fence companies in my New England area do. The company that does not install with cement is the only one around that supplies the vinyl panel fence with a small diagonal lattice top. Most of the diagonal lattice tops have large openings which I don't like. I am a very detail oriented person and if I am going to spend thousands of dollars on a fence, I should get the one I like......don't you think...
    But, you are right, in New England winters, we can have some strong gusts and windy weather. Since this fence will be situated on a grassy slope, I would feel better knowing that the posts are cemented into the ground.
    Do you think cementing the posts is the way to go for this kind of fence I am interested in purchasing?
  6. statjunk
    statjunk DIY Senior Member
    Jun 28, 2007
    Are they using pea gravel to place the posts or just right into the dirt? If you cement a post 6 inches into the ground it isn't nearly as effective as burying a post 40 inches into the ground with no cement. Consider that.
    If the posts are exposed wood at the ground then I'd avoid cement and use pea gravel. If they're vinyl then I don't think it matters.
    Tom
  7. jadnashua
    Many of the vinal fence posts are a sleeve that is fitted over a 4x4 wooden post. So, if that part that is burried is wood, sticking it into concrete may not be the greatest idea.
Similar Threads: Vinyl Fence
Remodel Forum & Blog In-floor heat under vinyl flooring? Mar 4, 2013
Remodel Forum & Blog Residential vinyl window replacement: Fairfield 70 Series Oct 30, 2012
Remodel Forum & Blog Ultramaxx Fusion-Welded Residential Vinyl Windows May 25, 2012
Remodel Forum & Blog Fairfield 80 Series Residential Vinyl Windows May 10, 2012
Remodel Forum & Blog Excalibur II Fusion-Welded residential Vinyl Windows Apr 27, 2012
