Video of my burner flame in Kenmore Power Miser 9
Discussion in 'Water Heater Forum, Tanks' started by vtxdude, Jan 3, 2010.
  1. vtxdude
    vtxdude New Member
    Nov 28, 2009
    NH
    I have uploaded a video of my burner flame to You Tube.....does this flame look normal? If you notice on the right the flame is taller and reaching up...it is hard to see but the flame is actually being drawn up into the flue......is this normal? I would think that the burner flame should be uniform pretty much all the way around.....
    What do you guys think?
    http://www.youtube.com/watch?v=U4aa_snIR30
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    higher on one side...
    it looks a little odd...
    one side is higher than the other...burning unevenlingly
    are you still planing on changing that out or what??
  4. vtxdude
    vtxdude New Member
    Nov 28, 2009
    NH
    Yes, I talked to plumber last week and he plans on doing it sometime this week..lot of freezing pipe calls I guess right around New Years Eve...my wife is returning from deployment from over in the sandbox this week so gotta make sure it isn't day she comes home!!
    Sorry got off track...but yes still plan on having it done. I'm hoping this is a good plumber (comes highly recommended) and sounds like he knows his stuff...if so I plan on having him replacing copper back to washing machines at some point as it is really ugly and mickey moused...didn't help that original plumber just pulled cold copper pipe down to put on top of new water heater......didn't bother to cut a new piece accordingly...another bullet in my beef with Sears
    Yes since day one the burner has been loud and it has always been higher on that one side...like I said the flame is actually being pulled up into the flue...any ideas why something like that might happen? I do recall the second plumber saying something to the effect that the vent pipe was super hot..like he was surprised by it? Wonder if some of the smell getting because flame is going up into flue
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    kinda weird I wonder if there is something funny with the flue baffle.
  6. Master Plumber Mark
    Feb 6, 2005
    flue baffle
    who knows , maybe their aint a flue baffle in this one
    or a rodent got down in the baffle , and you have been slowly cooking a squirrell or a rat......
    I would loook into that after you change it out...
  7. vtxdude
    vtxdude New Member
    Nov 28, 2009
    NH
    No there is a baffle ;) And no critters in there
    Does it matter in how the baffle is positioned in flue? I have it going from 9oclock to 3oclock is that ok?
    When the plumber removed the first water heater he pulled the baffle out ..the bottom part of the baffle was covered in what I guess was soot..and this was on a week old water heater...he said bad water heater...well looks like second one is the same deal ..I wonder if the flames leaping up into the flue chamber contributed to this? Is the flame reaching up because it is looking for air?
    I'm just sorta guessing here I guess...It is odd though huh? Gas pressure have anything to do with it?
  8. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    That is the flame burning on a brand new HWT? If that's the case you have some issues. The burner shouldn't be burning unevenly like that.
    Could be:
    1. Issue with gas pressure.
    2. Lack of primary air into the combustion chamber.
    3. Gas pressure is off of what it should be.
    4. Plugged up primary air orifaces.
    I would check those things 1st.
  9. vtxdude
    vtxdude New Member
    Nov 28, 2009
    NH
    1)The plumber coming over to install the Bradford White asked me if I had Sears out to check gas pressure..told him I was done with Sears and wanted Bradford White regardless....if issue with gas pressure...who can correct that? Can he or is it something gas company need to take care of? Sounds like he knows what he is taking about
    2) This is one of the main reasons I want the BW, I think they have a better primary air intake system as well as Rheem compared to AO Smith made heaters
    3) Is this same as 1?
    4) Things looks good, I cleaned under it a week or so ago and intake seemed clear of lint etc
    I'm hoping that is flame gets where it needs to be that combustion odors take care of itself......
    Can't be good with that flame darting up the flue like that
  10. Doherty Plumbing
    Jun 22, 2009
    Penticton, BC
    Lol yes 3 was the same as #1 sorry :p I'm tired.
  11. vtxdude
    vtxdude New Member
    Nov 28, 2009
    NH
    Lol np.....do any of my questions or theories make any sense?
  12. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    I'm still betting either the gas valve or the burner is plugged up, because of using copper for the gas line.
    John
  13. vtxdude
    vtxdude New Member
    Nov 28, 2009
    NH
    Could be..it has probably been on there since 1983 when place was built. So even for the Water heater only being hooked up for a little more than a month it could be plugged? Has burned this way since day one.
    When I have the Bradford White installed it will either be black iron or he said he could use the flexible stainless?
  14. Doherty Plumbing
    Jun 22, 2009
    Penticton, BC
    You guys must have some real nasty gas down there! We use copper piping for gas lines up here all the time and it's not even considered an issue... in fact it's quite often the preferred method!
  15. johnjh2o1
    Aug 9, 2009
    Retired
    Florida
    Next time you replace a heater remove the copper gas line tap it on the floor and see if you get the same blue colored flakes out of it that we do. I also would like to know if it is just in are area.
    John
  16. vtxdude
    vtxdude New Member
    Nov 28, 2009
    NH
    I'll have the plumber do that when he swaps out my piping this week
  17. vtxdude
    vtxdude New Member
    Nov 28, 2009
    NH
    Guys does position of baffle make any difference?
  18. Doherty Plumbing
    Jun 22, 2009
    Penticton, BC
    I have never noticed any flaking but then again I have never really looked for it.
    But next time I will check for it to see what I find.
  19. Master Plumber Mark
    Feb 6, 2005
    have a drip leg installed
    when you get the heater installed, have a
    drip leg installed on the inlet of the gas valve on the
    new heater...
    this tee with a nipple and cap on the end should
    catch all the crap that ever goes through that line..
    it dont cost anything to do and its code in many
    areas of the country....and a good practice.
  20. vtxdude
    vtxdude New Member
    Nov 28, 2009
    NH
    Yep will do Mark...noticed my gas line for furnace has one but not dryer....stainless steel connection.......flexible...fwiw the copper line is very thin and it does have the drip leg wonder if it being smaller diameter than the iron pipe changes gas pressure? If it is a gas pressure issue is anything plumber can do to fix it?
    Ok spoke to plumber tonight..tomorrow is the big swap out lol He will come by in morning to size job up and then got to FW Webb to get heater...Kenmore will go into my garage until I can convince Sears to come pick it up...good luck huh?
    Well I intend to really fight them to take it back, 2 bad heaters as far as I'm concerned.....2 very shoddy installation attempts and the second plumber could have killed us due to his unique venting with foil tape...I could run into an issue because I gave up on them but was not gonna have Sears try for a third time and waste more of my time...never again...an independent plumber from here on out for sure
    Hope I am making the right move!
  21. Doherty Plumbing
    Jun 22, 2009
    Penticton, BC
    Copper gas lines are smaller then natural gas lines because they have smoother surfaces and there for less friction loss across a given length at the same flow rates.
    I don't know how it works down there but up here in Canada you need to be a ticketed gas fitter. And a gas ticket is separate from a plumbing ticket.
Similar Threads: Video burner
Water Heater Forum, Tanks Loud burner? 75 Gallon US Craftmaster water heater (propane) see pic? Oct 25, 2016
Water Heater Forum, Tanks White, powdery residue in burner chamber Aug 14, 2016
Water Heater Forum, Tanks Ash looking substance on burner assembly Feb 5, 2015
Water Heater Forum, Tanks I have a GE 40 gal tank natural gas water heater. 40 BTU burner. Nov 4, 2014
Water Heater Forum, Tanks burner won't stay lit Mar 7, 2012
