Video Camera & Jetters
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Randyj, Nov 26, 2006.
  1. Randyj
    Randyj Master Plumber
    Nov 25, 2006
    Alabama
    Anyone have advice on cameras? I decided that I wanted to get into this "CHEAP" and got one on the "e" auction....really cheap (Comparatively speaking). It is only the camera and push line. Supposedly I'll be able to hook it up to my TV box (adapter) and get the picture on my laptop screen. I'm anxious for it to arrive UPS. I guess my question is "did I throw my money away"? Or is this really a good way to get started. I do know it has a 4" focal point, dimmer for LED lighting, and 100' of push line. I'm sure I'll be trying to rig up some sort of reel for the line.
    Now, I'm looking for an inexpensive jetter to use on drains/sewers. ANY IDEAS? I'm considering just buying a nozzle that I can stick on the end of my small "home use" quality pressure washer. I don't intend to do big pipe...so I'm just looking for like 100' of line and somehting that will handle 4" pipe with no trouble and hopefully something I can use on 1 1/2" pipe... would love to be able to run something like this thru sink and urinal traps...even toilets! Hopefully I'll be able to leave the snakes and augers at home... I hate having to drag them out and am always getting banged up side the head or pinching a finger with that big heavy bugger.
  2. hj
    jetter
    When you are jetting a line, you are injecting a lot of water into the pipe. If the drain is not working, and you are not outdoors, you had better have a plan to remove this water before it floods the building or room where you are working. Commercial jetters have a pulsating feature to help the hose turn corners and work its way through stoppages. Your home washer does not have that feature. Those two items are probably the only two that I would not consider going cheap on. A monochrome display is very hard to analyze to determine exactly what is happening in the sewer.
  4. Randyj
    Nov 25, 2006
    Alabama
    Thanks Hj... not monochrome, it's color. The ad has high claims... so I guess we'll see. I do know that surveillance cameras have come down in price and are pretty cheap... so, for the most parts the cost to manufacture these things are relatively cheap. Lots of variations. Hopefully my $350 will be a very good investment. Similar model with monitor and recorder was $748 then the more "commercial" versions jumped $1k - $2k in price.... I didn't want to buy another monitor with all the computers and tv's sitting around this place. Should not be a problem to make it work if it's all that it says it is.
    As for the jetter I'm considering just going ahead and buy a small complete system since I only am interested in doing home and light commercial work. I am not prepared to or interested in going for the huge pipes and industrial sized jobs. There's plenty of big companies around and I don't care to invest tens of thousands of dollars in equipment that I would seldom use. I just don't want to throw my money at junk. I've seen some things that claim to attach to pressure washers to do the same trick. Supposedly there's a bypass part that creates the pulsating function you speak of. Whatever I end up with I certainly hope it works. I wonder if I should also invest in a wet vac with a hose pipe drain attachment to clean up the mess... might be a good idea.
  5. hj
    tv
    As long as you have the capability of making a hard copy record of the sewer inspection, you should be okay.
Similar Threads: Video Camera
Plumbing Forum, Professional & DIY Advice Toilet Leak- Need Help! *Video included* Jan 2, 2017
Plumbing Forum, Professional & DIY Advice Has anyone ever seen something like this happen (video)? Dec 31, 2016
Plumbing Forum, Professional & DIY Advice Video: How A Farmer Shut The Fracking Supporters Up Apr 4, 2016
Plumbing Forum, Professional & DIY Advice Sink Stopper Caused Leak Below Sink (see video) - Pushed Down Stopper - Heard Pop Jun 5, 2015
Plumbing Forum, Professional & DIY Advice Bob Vila, Must watch this video Apr 23, 2015
