VFD to CSV sprinkler question
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by jpennin217, May 18, 2012.
  1. jpennin217
    jpennin217 New Member
    Feb 10, 2009
    I changed over to a CSV system after the electronic control in my VFD went out over the winter. The CSV is placed where the main line enters the house and I have great water pressure in the house a constant 50 psi or so. My issue is that my sprinklers are ran right out of the well and my pressure is about 30 psi at the most and I cannot run my sprinklers. How do I increase the pressure for my sprinklers? Thank you
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The bronze/brass CSV can go in the well. The plastic one probably can too depending on the weight that will be hanging off from it.
  4. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    If the sprinklers are tied in before the CSV, it sounds like the pump is not doing as much as it should.
  5. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    The CSV should be placed before the sprinklers.
    When he gets 50 PSI in the house but only 30 PSI at the sprinklers, my guess is the pump isn't running and the water is back-feeding from the pressure tank. While the pump is running, he should see more pressure. If in fact he only sees 30 PSI with the pump running and the sprinklers on, then almost certainly the pump is not keeping pace with demand and moving the CSV would not help.
  6. hj
    To produce ANY pressure above 30 psi, the pump would have to output MORE than that. If the sprinklers are draining the excess pressure above 30 psi, then they are using more water than the pump can produce, and he is at the point on the pump's curve where the volume and pressure are balanced with the demand.
  7. jpennin217
    Feb 10, 2009
    Thanks for the relies. I'm a pretty good handyman but it sounds like I need to get the well guy out to take a look. No way I can put a csv in the well with my equipment.
  8. jpennin217
    Feb 10, 2009
    I replaced my high pressure sprinklers with low pressure sprinklers. I guess I can take a few off the line and see what happens. But the most on one line is 6 the rest are 5.
  9. valveman
    Mar 15, 2006
    Lubbock, Texas
    If you have different sprinklers now, we don’t know the change in flow. If they are tied in before the CSV, you will have low pressure (and only 1 GPM) to the sprinklers until the tank drains and the pump is started. But then you have water directly from the pump, and if the pressure is low, you have on too many sprinklers.
Similar Threads: sprinkler question
Pumps and Tanks Well Forum & Blog. Water is life. Helplease....Sprinkler pump and pressure tank Yesterday at 7:51 PM
Pumps and Tanks Well Forum & Blog. Water is life. Sprinkler pump flow through at intake Apr 16, 2016
Pumps and Tanks Well Forum & Blog. Water is life. New Well Pump with Fire Sprinkler Jun 8, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Need help! - Low pressure in sprinkler system - The well to blame? Solutions? Jun 8, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Garden sprinkler system jet pump setup? Jun 7, 2014
