NMPastor
I'm trying to mount a vessel sink on 1 1/4" silestone. The sink has an overflow.
Because the Silestone is 1/2 inch thicker than standard, the drain that came with the valve set (Hansgrohe) isn't long enough to allow the treads to get far enough down to hold the sink down to the countertop. I purchased a really nice Decolav pushbutton drain with a long enough threaded portion to do the job.
Unfortunately, the very bottom of the drain hole on the porcelain vessel sink (Kingston Brass - I now know why it was at Overstock.com) has a slight imperfection; the drain hole is slightly out of round. The drain body won't quite fit.
Am I going to cause a problem if I take a rasp to the drain hole in the sink and remove the imperfection...open it in one place just a little more to allow the drain body to fit?? Is breaching the glazing there going to give me problems over the years with this thing? Could I seal that back over with epoxy to keep the water out of the porcelain? Do I need to keep the water out of the porcelain?
Alternatively, if I use the Hansgrohe drain, but attach it only to the vessel sink, what type of adhesive would I use to bond the vessel to the countertop? Silicone? Some other form of industrial-strength adhesive?
Thanks.
Thanks.
