Vessel Sink Installation
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by apnep, Sep 25, 2012.
  1. apnep
    apnep New Member
    Sep 25, 2012
    TX
    Please help!
    I am trying to install my vessel sink but I can't stop it from leaking at the base of the sink. What the heck am I doing wrong??
    I put plumber's putty under the lip of the drain, inserted the drain into the hole, attached the gasket and nut directly underneath. How do I get it to stop leaking?
    Do I need to put plumber's putty on the gasket too? I don't think I over tightened.
    Thanks in advance,
    Angela
  2. jadnashua
    There are threads on the drain pipe for the nut to tighten the drain to the bowl. Sometimes, the gasket seals to the bottom of the sink, but water can leak along the threads. So, loosen that nut, rub some plumber's putty on the threads near the point the nut will be when it is retightened, retighten the nut and see if that stops it.
  4. hj
    Is the locknut tightened against the sink or the bottom of the countertop?
Similar Threads: Vessel Sink
Plumbing Forum, Professional & DIY Advice Stone vessel sink drain problem Dec 2, 2016
Plumbing Forum, Professional & DIY Advice Vessel sink issue Sep 5, 2016
Plumbing Forum, Professional & DIY Advice Supply Lines to Vessel Sink Too Short Nov 15, 2015
Plumbing Forum, Professional & DIY Advice Vessel sink size question Nov 23, 2013
Plumbing Forum, Professional & DIY Advice Semi-recessed vessel sink - with overflow? Milforde Semi-Recessed Porcelain Sink Nov 25, 2012
