Vessel bowl basin slow drainage problem
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by JMCC, Jun 14, 2008.
  1. JMCC
    JMCC New Member
    Jun 14, 2008
    Hello all,
    I just installed a vessel bowl basin in my bathroom and it looks great. However, it doesn't drain adequately. The bowl would actually overflow if I left the water running. I shortened the tail piece to see if it would help and it didn't.
    I thought the problem might be the lack of an overflow on the basin, but the sink in the kitchen doesn't have an overflow and yet it drains fine. Nevertheless, would a pro-vent help?
    It does have a 19-hole drain with no stopper. Could this be hamplering the flow?
    Any and all advice would be welcome.
    Thanks,
    JMCC
  2. jimbo
    jimbo Plumber
    Grid drains are notorious for this. Try drilling out 5 or 6 holes to about 1/4" or 9/32" diam.
  4. hj
    drain
    You are being air-locked by the bubble between the trap and the strainer. The openings in the strainer are not large enough for the air to escape AND let the water drain down at the same time. It is compounded by the strainer being flat so that there are no pressure differentials created. A domed strainer or larger holes will cure the problem.
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Some of the worst ideas in plumbing survive by being "Oh So Fashionable"
  6. JMCC
    JMCC New Member
    Jun 14, 2008
    Well, I replaced the 19-hole grate with a 15-hole one with larger holes. Not good enough. I then drilled out 6 of the holes to .25". Still not enough. I finally drilled out the 6 center holes to .3125" and that did the trick!
    Thanks for the advice hj and jimbo.
  7. Terry
    Aug 17, 2004
    vessel drain without overflow
    The drain by Mountain Plumbing Products works better with vessel bowls without the overflow.
    http://mountainplumbing.com/mt749
    Or the Kohler K-7124
  8. JMCC
    JMCC New Member
    Jun 14, 2008
    And it's very nice looking too!
  9. rickparsons
    rickparsons New Member
    Jan 18, 2010
    Colorado
    Pop Up Drain in Vessel Sink Drains Slowly
    I have a vessel sink that drains slowly. I figured it was the lack of positive pressure. I have a pop up drain with just two small oval openings for water and air to go through. Any recommendations on how to get past this problem on a sink with no overflow? Thanks.
Similar Threads: Vessel bowl
Plumbing Forum, Professional & DIY Advice Granite Countertop for a vessel bowl Dec 16, 2012
Plumbing Forum, Professional & DIY Advice Stone vessel sink drain problem Dec 2, 2016
Plumbing Forum, Professional & DIY Advice Vessel sink issue Sep 5, 2016
Plumbing Forum, Professional & DIY Advice Polyglass pressure vessel Jun 20, 2016
Plumbing Forum, Professional & DIY Advice Silicone or Putty to seal drain to vessel? Dec 17, 2015
