Bathroom slow drain. Very odd problem !!
ianmulluk
I have a very slow draining sink in the bathroom.
I have removed the p trap and cleaned it out.
I have cleaned the other pipes and can pour water down them successfully.
I can pour water throught the p trap when it is not connected.
HOWEVER - when I reconnect it all , after only 1 cupfull of water down the sink it starts backing up .
How can this be ??
The p trap works fine when i disconnect it and run water through it and we have NO blockage
Really Odd - HELP !!
Thanks
Ian
Gary Swart
Yakima, WA
Slow drain
I've seen older homes that did not have a vent for the bathroom basin. That's what it sounds like to me. Check to see if there is a vent or if the vent is blocked. If there is no vent at all, you might look at a Studor vent for the basin.
SRdenny
Plumbing Contractor
SF Peninsula
Remove the pop-up and inspect inside the drain.. There may be an obstruction in the overflow holes in the tailpiece.
Jimbo
San Diego, CA
If as little as one cup of water backs up I agree that the problem is right there in the pop up drain assembly. An amazing amount of "gook" ( soap mixed with decaying hair) can build up there.
