Very Loud Boiler Pump
Discussion in 'Boiler Forum' started by Kiko, Dec 5, 2009.
  1. Kiko
    Kiko Member
    Jul 20, 2009
    Royal Oak, Michigan
    I live in an apt. complex with boiler baseboard heat, and each unit has their own pump, located in the laundry room. One of the pumps is making a very loud grinding noise. I called in a maintenance request, and when I followed up, they told me that the service man couldn't hear anything, so he just oiled all the pumps. Today, it is louder than ever and telegraphing the noise through the pipes in the wall. It is driving me crazy.
    Any ideas why this pump is so loud, and if it can be fixed or just needs to be swapped out.
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Bad bearing assembly or coupling.
  4. jadnashua
    Depending on the age and capacity required, you may have a motor driving a pump, or a circulator, which is a motor integrated with a pump. You can't really oil a circulator, but you may be able to oil bits of a motor or the shaft going to a pump. Often, once they start to make noises, it's time to replace.
  5. Kiko
    Kiko Member
    Jul 20, 2009
    Royal Oak, Michigan
    Thanks a lot.
    Well, it got so loud, I got them back over here.
    They replaced the coupler, and it's quiet as a mouse.
    The reason no one else was complaining is because that pump actually comes in contact with my pump, which sent the vibrations screaming through my pipes. They still haven't addressed that problem.
Similar Threads: Very Loud
Boiler Forum Radiant floor heat zones very puzzling...any ideas? Feb 3, 2016
Boiler Forum Heat recovery from oil fired boiler May 20, 2015
Boiler Forum Multiple loud bangine noises when heat is called for Feb 3, 2015
Boiler Forum System Pump Suddenly Louder. Apr 4, 2013
Boiler Forum What's in the "clouds" emitting from gas boiler power vent? Feb 11, 2013
