vertical-to-horizontal transition: long bend only or or Y plus 45 with cleanout?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Steve Zerby, Jun 14, 2013.
  1. Steve Zerby
    Steve Zerby Remodel Contractor
    Jun 13, 2013
    Remodeling contractor
    Upstate NY
    Dropping my main 3" PVC drain line from second floor bathrooms to basement, then turning 90 degrees to horizontal run of about 30 feet to the septic tank (20 indoors, 11 feet from house to septic).
    At the vertical to horizontal transition I have room for a wye with 45 and a cleanout behind it , but would it be better to simply use a long bend for less turbulence in the turn and not worry about a cleanout?
    Thanks,
    Steve
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    You need a cleanout at the base of a stack so a wye and 1/8 bend with an eco in the end of the wye is the way to go
  4. Steve Zerby
    Jun 13, 2013
    Upstate NY
    If I have room, would it be better to put the clean out access in the vertical section just above the bend and use a long bend at the bottom? I know I'm over thinking it, but it just seems to me that turning that corner with the wye plus 1/8 is still going to introduce more turbulence than just a bend.
    Steve
  5. Tom Sawyer
    Nov 29, 2010
    Maine
    No it wouldn't. The proper way is with a wye and 1/8 bend or a combo fitting if you can find one. The clean out needs to go in the horizontal section.
Similar Threads: vertical-to-horizontal transition
Plumbing Forum, Professional & DIY Advice Advice for transitioning PVC to non-standard cast iron Oct 10, 2015
Plumbing Forum, Professional & DIY Advice What kind of drain pipe is this? How can I best transition to PVC? Feb 8, 2015
Plumbing Forum, Professional & DIY Advice PVC transition to Cast Iron May 31, 2014
Plumbing Forum, Professional & DIY Advice Abs-PVC Transition Cement for just Abs by mistake May 6, 2014
Plumbing Forum, Professional & DIY Advice transitioning from galvanized to copper Dec 16, 2013
