Vertical drain drop from toilet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by hanktr, Feb 15, 2008.
  1. hanktr
    hanktr New Member
    Feb 15, 2008
    I'm installing two back-to-back toto drake toilets and have been told by toto technical staff that they may not work properly with my 50 year old opposed cast iron tee. A double combination wye was suggested.
    Can I come directly from the closet flange to the wye with a 1/8th bend at the closet flange?
    I read in one place on-line, Plumber's Handbook, that even below a toilet, the max vertical drop is 24 inches, just like a sink trap.
    I know a 45 degree wye is not a vertical drop, but it is not a 90 degree, either. Is this code? Will I violate code, or have plumbing issues if I go straight to the 4 inch stack with the 45 combo wye?
  2. hj
    toilets
    The first thing to understand is that if you use a Y and 1/8 bend, double Y and two eighth bends, or a double combination Y-1/8 bend, your toilet opening(s) is/are going to be a lot more than 12" from the wall. You need a double fixture fitting that is similar to a double combo, but narrower so it does set the toilets at the proper distance.
Similar Threads: Vertical drain
Plumbing Forum, Professional & DIY Advice Vertical Drain lines for new bathroom? Nov 29, 2015
Plumbing Forum, Professional & DIY Advice Does a shower drain have to run vertical to the trap? Mar 25, 2015
Plumbing Forum, Professional & DIY Advice Vertical drain or a vertical stack? May 11, 2014
Plumbing Forum, Professional & DIY Advice Easy, I think: Can a regular elbow trainsition from a vertical to horizontal drain? Feb 13, 2012
Plumbing Forum, Professional & DIY Advice How to drain the vertical 2" PVC sewage pipe above check valve? Sep 11, 2011
