Are there any issues with using a stack vent as the vent for a WC? In my case, the WC drain is currently the top most drain feeding into the vertical stack (the stack becomes a vent above this point.)
I had a plumber tell me that it's not preferred to do this. Something to do with a slug of water moving real fast when it hits the vertical pipe. I didn't quite follow.
Ultimately, I need to alter this stack to accommodate a relocated sink drain. The 1.5" sink drain currently enters the stack at the same elevation as the WC. I'm not sure if this is even OK or not (I'm thinking no). Regardless, my new sink location is going to force its drain to tie into the stack lower.
