Venting Under a Porch-National Code Reference
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by North Jersey, Oct 7, 2009.
  1. North Jersey
    North Jersey New Member
    Jan 1, 2009
    I finally broke down and bought a direct vent tankless water heater to overcome the combustion problem I was facing with the standard power vent model I own. At any rate, I find myself in need of venting the heater under a 7' unenclosed entry porch. I'm looking for a national code reference that addresses clearance under a porch. I searched ANSI Z223.1/ NFPA 54, but I couldn't find anything. Canadian code requires 1' clearance from the porch and, I believe, two unenclosed sides. I'm looking for something that will convince my local inspector that this is an acceptable location for the termination.
  2. jimbo
    jimbo Plumber
    San Diego, CA
    National Fuel Gas Code 12.3.5....direct vent appliances shall be installed in accordance with manufacturer's instructions..and with 12.9.3, which says for up to 50,000 BTU, vent terminal shall not be within 9" of any opening into the building.
    That's all I can find. Can not find specifics about under the porch. Check with the mfg.
  4. North Jersey
    Jan 1, 2009
    Thanks. I'll bring the 9" clearance thing to the inspector. The manufacturer (Takagi) has guidance for Canada (12" clearance from the deck), but says to defer to local guidance in the US. *update* The inspector bought off on the vent under the porch.
  5. jimbo
    jimbo Plumber
    San Diego, CA
    And thus the buck is passed.
Similar Threads: Venting Under
Plumbing Forum, Professional & DIY Advice Under slab new plumbing help - venting/santee Aug 1, 2016
Plumbing Forum, Professional & DIY Advice Wet Venting bathroom group in new construction (Under Slab) Apr 11, 2016
Plumbing Forum, Professional & DIY Advice Two Basement Sink Install w/undersink pump - venting Nov 28, 2015
Plumbing Forum, Professional & DIY Advice Exceptions to horizontal venting under floor? Apr 27, 2015
Plumbing Forum, Professional & DIY Advice Properly venting a toilet underslab, help please! Jun 25, 2014
