Erc
I'm in the planning stages of a master bath remodel and would like to slightly relocate the current tub and shower positions to allow for a larger shower. However going this route seems to limit available walls to run vent piping. Must a drain line say from shower pass by the vent before going vertical, or is it generally acceptable (Atlanta, GA) to go vertical, being wet vented from an opposite side of the vertical run. If that doesn't makes since which it likely doesn't, I have attached a few sketches of What I am getting at. Thank you very much!
