venting question kitchen sink under window
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by gsici, Oct 1, 2010.
  1. gsici
    gsici New Member
    Jan 24, 2009
    I am moving my kitchen sink to the opposite wall and as such I will run new drain into the basement and connect to the main drain and vent into the attic and connect to the main vent.
    The question is with my sink under the window which is the best way to vent. I am used to wet vents going straight up from the drain.
    My options are 1) have a stubout with a 90deg and run 2 feet till the end of the window and connect into a sanitary T that drains into the basement and vents through the roof. The problem with this option is that the drain pipe going into the basement would run right over the electrical panel. Although there is a lot of room in the joists to run the pipe between the joists toward the basement beam, my concern is that it is right over the panel.
    The second option is to stubout with a 90deg and run one foot (still under the window) and connect into a "T" at this point. The drain would be between joists just over from the panel. However the vent would go up to the window sill and then take a 90deg turn for another feet, and then run up along side of the window. The window sill is 40" above the ground. Is this option viable or is there a beter way. Thx
    Gino
  2. hj
    And, what is the problem with it over the panel? Do you intend to install it so it leaks onto the panel? If not, then there is no problem.
  4. Gsalet
    Gsalet George the Plumber
    Sep 19, 2010
    San Francisco
    Why are you using a tee on the vent? Can't you rise up from the drain tee to the just under the window go horizontally to the edge of the window and straight up to the attic??
  5. hj
    That was his second option. Which is "better" depends on the rest of the plumbing system which we cannot see.
Similar Threads: venting question
Plumbing Forum, Professional & DIY Advice Venting question on a double lav on outside wall. Tuesday at 9:13 AM
Plumbing Forum, Professional & DIY Advice Bathroom sink remodel venting/drain question Feb 24, 2017
Plumbing Forum, Professional & DIY Advice Bathroom planning advice (venting questions primarily) Feb 12, 2017
Plumbing Forum, Professional & DIY Advice Venting question Jan 20, 2017
Plumbing Forum, Professional & DIY Advice Venting question: sanitary tee vs wye + 45 Jan 3, 2017
