Venting In Vaulted Celing
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by sugoii, Sep 26, 2005.
  1. sugoii
    sugoii New Member
    Sep 26, 2005
    I have a kitchen sink on the front of the house that I vented along the slope of the vaulted ceiling and then back down the other side where it ties to another drain and the vent on the back side of the house. The vwent will fully drain on both sides of the house, so as far as functionality there is no question that it will work. My inspector will pass it if I can give him code refrences that allow such venting. I have no idea where to start, and at this point don't have access to the code. Is there an allowance for venting this way in the international plumbing code?
  2. RioHyde
    RioHyde Plumber
    Sep 24, 2004
    Cincinnati, Ohio
    While the IPC doesn't address running a vent in a vaulted ceiling specifically, it does state the following in Chapter 9 Section 905.2:
    Grade - All vent and branch vent pipes shall be so graded and connected as to drain back to the drainage pipe by gravity.
    With the new vent being connected to the vent on the backside of the house and therefore to a drain on both sides of the house, your vent does drain by gravity to a drainage pipe. I have seen it done this way and pass here in Cincinnati. The only thing the inspector MIGHT argue is the word "the" in "drain back to THE drainage pipe by gravity" rather than the word "a".
    Good luck!
  4. hj
    vent
    As long as the inspector is being reasonable about it, which the ones in this area would not be, reference him to the "yoke" vent for an island sink drain, which is exactly the same thing except on a condensed scale.
  5. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    i don,t understand why your doing this
    why not have 2 roof vents ,one on each side. island vents don,t have that option
  6. hj
    vent
    He may be like a lot of people and doesn't want a vent exposed on the front of the roof.
  7. toolaholic
    Jul 16, 2005
    Marin Co. Ca.
    thank,s H J
    i kinda guessed that was the reason. Your inspectors can,t be as bad as S. F.
    don,t get me started !
Similar Threads: Venting Vaulted
Plumbing Forum, Professional & DIY Advice Venting madness: Adding a second washer, moving one. Thursday at 7:43 PM
Plumbing Forum, Professional & DIY Advice Shower venting details/ dry run Feb 15, 2017
Plumbing Forum, Professional & DIY Advice Bathroom planning advice (venting questions primarily) Feb 12, 2017
Plumbing Forum, Professional & DIY Advice Please tell me if this venting setup will work correctly. Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Venting a bathroom Feb 7, 2017
