Venting For Tub/Toilet Drain
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by crokett, Jul 26, 2010.
  1. crokett
    crokett New Member
    Jul 26, 2010
    Mebane North Carolina
    Below is a pic of my existing drains. Ignore the red/blue lines, those were for something else. There were two toilets, 2 tubs and 2 vanities. The tubs and 2 toilets tied into the drain with no tees to a vent. The line on the left heading away from you is the 3" line that runs over to the wall and heads out to the septic. The one on the right parallel to it is a 2" line from one shower. You can just see in the top left a wye coming down, that is from one toilet. You can't see (out of the pic at the top) the other 3" wye from one vanity. At the bottom of the pic on the left of the 3" line you can see a trap. That is the 2" from the other shower and ties into the line coming from the left which is 3". To the left of that trap you can see another 3" wye coming down, that is the other toilet. Out of the pic on the left it transitions to 2", that is the other vanity. That vanity tees into ts own 2" vent. I suspect the 3" wye for the first vanity actually is 3" all the way up and is the vent for the rest of the fixtures, since none of them tee into a vent.
    Question is, why do the toilets and tubs not tee into vents? I am guessing that it is a matter of distance to the 3" vent and these were wet vented? When the house was originally plumbed there were no fixtures upstream of the 3" vent. Now there is another bathroom upstream of that. I ripped the fixtures out last weekend as part of a bath remodel. I will be installing a whirlpool tub, a toilet and 2 vanities. The tub and toilet will be next to each other and will be installed more or less where the 2nd vanity on its own 2" vent was. That is, to the left in the pic. I will be reusing part of the 3" line coming in from the left that wyes into the main running tot he wall. The linear distance would be about 4' to the main drain line, then another 8' back upstream to the line to the 3" vent. The vanities will both be on the same wall where the 3" vent is now. So for the new tub and toilet, do I need to bring a 3" line up and over in the attic to the existing 3" vent? Or can they just be installed like the old fixtures were and wet vented? If the tub/toilet need their own vent I think I read somewhere that the toilet vent needs to be downstream of the drain?
    Thanks for any suggestions. This forum was recommended by a few people.
    [​IMG]
    DanielAZ likes this.
  2. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    EVERY fixture needs a vent. Either a dry vent or a wet vent.
    Depending on your local codes there are quite a few rules to wet venting. One of them is that YOU CANNOT wet vent passed a water closet. That is why toilets are always tied in LAST on a wet vent system. So if you were to add more fixture you would need to tie those fixtures in upstream of the toilet connection.
    Better you you create an additional wet vented system through the new vanities and tie that new system in downstream of the existing toilet and wet vented system.
  4. crokett
    crokett New Member
    Jul 26, 2010
    Ok, I labeled the pic to make it more clear. The tub drain will be repurposed for the 2nd vanity. The existing vanity drain is upstream from the wc drain at the top of the pic and will be reused. The added vanity will be vented to that one, which is direct-vented. The toilet drain at the top of the pic will go away. The shower trap will go away. The toilet drain on the left of the pic will go away. That run will be repurposed for the new bath and wc. Where it says 'to 'lav' there was a vanity there outside the pic on the left on its own 2" direct vent. I will repurpose that vent for the tub and new WC. The tub will direct-vent. The new WC tie in approx 14" downstream and wet vent into that vent. I don't think that breaks any of the rules as I understand them, since the toilet that was on that run I think wet vented to that vent. I don't ever plan to add any new fixtures upstream. or downstream on that run.
Similar Threads: Venting Tub/Toilet
Plumbing Forum, Professional & DIY Advice Tub/Toilet Venting Nov 8, 2008
Plumbing Forum, Professional & DIY Advice Yet another question about wet venting. Apr 20, 2017
Plumbing Forum, Professional & DIY Advice Venting - toilet then shower then vent Mar 29, 2017
Plumbing Forum, Professional & DIY Advice Is my venting adequate for what I have Mar 21, 2017
Plumbing Forum, Professional & DIY Advice Venting question on a double lav on outside wall. Mar 21, 2017
