Venting emergency drain.
Discussion in 'IPC Plumbing Code Questions' started by pdfj, Feb 4, 2013.
  1. pdfj
    pdfj New Member
    Feb 4, 2013
    Las Vegas, NV
    Code allows the use of a wet vent for the bathroom group which in my case is a sink, toilet, and shower drain. About 8-10 feet down stream of this group I have a washing machine drain with its own vent. I also need a emergency drain in my mechanical room. Does this need a separate vent?
  2. frodo
    frodo New Member
    Jun 29, 2013
    plumber
    Mississippi
    yes, is the short answer. i am a upc plumber. the ipc drawing you have. altho code correct. if the vent is rolled, goes against everything i was taught
    it is my understanding, that it was adopted, due to structursal restraints. and or difficult roughing in situations when the correct fall can not be achieved stacking the fittings.
    so that said. can you add a vent or 2, that toilet will pump and the shower will gurgle. it wont happen today. but down the road
    when the pipes no longer scour them selves and you get a little build up. on the walls of the pipe. the router rooter man will be your bestest friend. others will disagree or not
  4. hj
    YOu show a "closed system". Which way does the water flow to the main line? You can connect the floor drain to the lavatory's vertical riser and comply with venting requirements. Your other drain, however, may not depending on the direction of flow.
  5. Terry
    Aug 17, 2004
    Only if you want it to remain sealed when any othe plumbing in the home is used.
    Yes. By all means do all plumbing fixtures correctly. Some little used drains, like floor drains may even need trap primers to keep them from drying out.
    A washer runing by that floor drain will suck it dry though.
Similar Threads: Venting emergency
IPC Plumbing Code Questions Toilet wet venting Jan 25, 2016
IPC Plumbing Code Questions Wet venting "by the code" Jul 8, 2014
IPC Plumbing Code Questions venting tub under slab into p trap? Aug 1, 2011
IPC Plumbing Code Questions branch arm length if not stack venting Jun 21, 2011
IPC Plumbing Code Questions Vet my Venting please? IPC code Jul 28, 2010
