venting a water heater through a wall???
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mikeyvon, Jan 5, 2008.
  1. mikeyvon
    mikeyvon New Member
    Nov 14, 2007
    California
    Building a new house and trying to figure out my hot water. I have thought about tankless (and I still am), but I think I would much rather go with a regular tanked unit. It is me and my wife with 2 little ones. The house will have 1 shower, 1 soaker bath, 1 bath/shower combo, 3 lavs, 1 utility sink, 1 kitchen sink, and a dishwasher. We generally do not use hot water for clothes washing.
    The water heater will go in the utility room on the first floor next to an outside wall. I do not want to vent up to the roof unless it can be done in a 2x6 wall.
    I know of powervents but I hear they can be loud and troublesome.
    What options do I have for water heaters that can be vented out a wall instead of out of the roof?
  2. jimbo
    jimbo Plumber
    Everyone makes what is called a "direct vent" water heater. Vents horizontally, does not have a vent fan. They are pricey.
  4. mikeyvon
    mikeyvon New Member
    Nov 14, 2007
    California
    ok good, that is what I thought but was not sure. How pricey is pricey? Any recommened brands? I think I would like a larger unit as our 40 gal unit in our current home does not cut it.
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I have used a Rheem Powervent for years. It is not noisy. It vents with PVC or ABS pipe through the side of the house. Newer models can use smaller pipe and run for longer distance. I would suggest you look seriously at them. Tankless are discussed on this forum quite a bit. The majority of the opinions are that they are very costly to maintain, they do not provide very much hot water in colder climates, it is next to impossible to find anyone to service them, and are not at all cost effective. I would suggest you research the archives to read the comments yourself.
  6. construct30
    construct30 New Member
    Jun 16, 2007
    NorthWest PA
    Most code officials are very strict about direct vent water heaters or fire places, some don't allow them, you better check first, make sure it is installed to code for your area. Windows, doors, decks, electric services, meters, and many other issues for outlet.
  7. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Mikey, Where are you located? Southern US Tankless is a very viable option... Not so much so in the frozen northern wastelands.
Similar Threads: venting water
Plumbing Forum, Professional & DIY Advice Gas Hot Water Heater leaking (Power Venting) Jan 4, 2011
Plumbing Forum, Professional & DIY Advice Need Advice on preventing drilling into Water Lines - Grab Bar Installation... Aug 29, 2010
Plumbing Forum, Professional & DIY Advice question on water heater venting (orphaned water heater) Aug 22, 2010
Plumbing Forum, Professional & DIY Advice water heater venting Aug 10, 2007
Plumbing Forum, Professional & DIY Advice Side venting a water heater and boiler Jan 13, 2005
