Venting a kitchen sink
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jpiazza, Jun 11, 2007.
  1. jpiazza
    jpiazza New Member
    Jun 11, 2007
    Hi. I'm moving the sink in my kitchen to the other side of the room. There is a bathroom about 10 feet away with it's own dedicated drain and vent stack. Can I vent my new sink by going up to the ceiling, about a 6 foot rise, over to the existing sink, about 10 feet down to the existing vent, about 4 feet, and tie into it there. From there on it vents to the main stack. It will be tying into the vent above the top of the proposed sink. Thanks in advance.
  2. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    I don't quite understand your vent. You're not proposing that your vent line go down (elevation) to tie into the other sink's vent are you? If so, that's not permissable.
  4. jpiazza
    jpiazza New Member
    Jun 11, 2007
    Well sort of. It goes up first, then across then down to the bathroom sink's vent. There the bathroom sink vents to the main stack and out the roof.
  5. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    The vent needs to be sloped up, not down. This will allow the sewer gases to escape and any condensation that may form in the vent will drain back into the sewer system.
  6. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    All vents must slowly rise towards the vent stack. What you are proposing will build what is similar to that of a trap.
    Moisture collection from damp sewer gases along with rainfall accumulations will fill that low spot with no way to drain out. Basically eliminating the vent.
  7. hj
    vent
    It will work as long as condensation can drain out of either end of the horizontal section, although most inspectors would reject it.
  8. jpiazza
    jpiazza New Member
    Jun 11, 2007
    Thanks for the responses. I don't think there will be a possibility for any condensation to build up as both ends of the vent will be leading directly to waste. So I just need to slope it one way or the other and find the right inspector. Thanks again.
  9. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    Good point
    We're ALL trying to find the RIGHT INSPECTOR !!! PLEEEEZE WHEN YOU FIND HER, SEND HER MY WAY :D
  10. Cass
    Cass Plumber
    Nov 12, 2005
    We had the first woman in OH to receive a Master Plumbers Lic. work in the inspection dept. of the county I worked in................she was fair.
  11. toolaholic
    Jul 16, 2005
    Marin Co. Ca.
    That's interesting , She said " You were GREAT ";)
Similar Threads: Venting kitchen
Plumbing Forum, Professional & DIY Advice Kitchen Sink Drain Pipe too High...venting question Sep 23, 2015
Plumbing Forum, Professional & DIY Advice Kitchen sink venting question Mar 9, 2014
Plumbing Forum, Professional & DIY Advice Stubborn kitchen sink venting problem Jun 30, 2013
Plumbing Forum, Professional & DIY Advice Venting a kitchen sink May 9, 2013
Plumbing Forum, Professional & DIY Advice Kitchen sink venting height Mar 31, 2013
